Old 03-18-2004, 03:25 AM   #1
I drive a WRX wagon
Member#: 9219
02 IS300 5sp
Default Oil pan question
Has anyone tried to replace the oil pan. Is there any other way to get to the four (?) bolts behind the oil pan without dropping the crossmember or anything else like that? Thanks.
I drive a WRX wagon is offline   Reply With Quote
Old 03-18-2004, 10:59 AM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
this might shed some light, no instructions, just some findings
http://forums.nasioc.com/forums/show...hlight=oil+pan
vile is offline   Reply With Quote
Old 03-18-2004, 11:00 AM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Jack the engine up...and its a complete pain in the *** but its possible. Get a u-joint or a wobble extension.
cdvma is offline   Reply With Quote
Old 03-18-2004, 01:35 PM   #4
I drive a WRX wagon
Member#: 9219
02 IS300 5sp
Jack the engine up.....oh man. Ill see what works. Thanks for the info!
Old 03-18-2004, 02:45 PM   #5
treebeard
Member#: 33637
I just used a mixture of 1/4 inch extensions and flex joints. It is a real pain in the ass, but it will work. You don't need a 3/8 or 1/2 inch socket to break those bolts loose, they are not that tight.
Now, cutting the pan seal and actually removing the pan was even harder ...
treebeard is offline   Reply With Quote
Simple oil pan question MS WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-07-2008 07:16 PM
oil pan question bluice Subaru Conversions 2 11-15-2005 05:38 PM
Oil Pan Questions ExecNav Normally Aspirated with bolt-on Forced Induction Powertrain 6 08-14-2004 04:08 AM
Help! Oil pan question scrmnsmn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2002 12:04 AM
oil pan question imprezaboi Normally Aspirated Powertrain 1 02-12-2002 03:29 AM
