Vancouver Impreza Club
Old 03-18-2004, 03:35 AM   #1
banman
Member#: 12408
2006 Legacy GT
Default Hella Supertones?
I'm considering getting a pair . . . but I'm trying to decide between the 300/350Hz combo and the 300/500Hz combo (the latter is more expensive, and louder). I'm less concerned about loudness than with the sound - has anyone heard both of these? Is there much difference?
banman is online now   Reply With Quote
Old 03-18-2004, 12:11 PM   #2
urbanwhitetrash
Member#: 5613
2007 Acura MDX
um, one is louder than the other
Truth be told, depending where mount the horns you won't be able to tell the difference in the car. Although you'll sure know when your alarm goes off.
urbanwhitetrash is offline   Reply With Quote
Old 03-18-2004, 12:37 PM   #3
alexs001
Member#: 8096
1998 Impreza 2.5RSTi
Rally Blue Pearl
I didn't even know there were different kinds...
alexs001 is offline   Reply With Quote
Old 03-18-2004, 12:47 PM   #4
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
I think the "dual kit" comes together with 300/500Hz. It would be "louder" because the 500Hz would be a higher frequency (ie. more shrill sounding, sounds almost like a banshee)
I think for the 300/350 combo you have to buy each horn separately, but I think 300/350 would sound closer in tone to traditional stock horns.
Honestly, whichever route you go, it's not like you are going to honk them all the time to see if you can tell the difference .
I have an in-cabin toggle switch so I can trigger either stock (2 horns, better dispersion) or stock + HELLA (2+2=4 horns, dispersion + hella piercing) all at once triggered by the horn switch. I did, however, make sure to power the HELLA's with their own dedicated relay though.
Overkill? yes, definitely . -- btw, I've only had to really use it once (to get someone out of the way in a hurry) -- let's just say it worked
-- Dendrobium
Dendrobium is offline   Reply With Quote
Old 03-18-2004, 01:13 PM   #5
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Dang, this guy takes his horns seriously.
Another thumbs up for the Supertones. They're the electromechanical type, which seems a lot more reliable than the air horn type. I don't know how KFC kept his air horns working for so long when mine and all my friends' went within a year or so.
I once organized a group buy for the Supertones and would be interested in a set myself ... where are you getting them?
Necromancer is offline   Reply With Quote
Old 03-18-2004, 01:14 PM   #6
STi-Mulation
Member#: 34722
05 BMX
Go with the 300/350. Unless you really want to give others a rude shock
BTW it sounds just like the stock BMW/Benz euro luxury type of horn.
STi-Mulation is offline   Reply With Quote
Old 03-18-2004, 01:19 PM   #7
banman
Member#: 12408
2006 Legacy GT
I think I'm going to buy them off eBay - the 300/350 pair is going for about $45US, the 300/500 pair is about $65US.
When I get them, do you guys want to have a "tech night" for the install? I'm thinking of painting them blue instead of red and hooking them up to a switch as well . . .
Old 03-18-2004, 01:31 PM   #8
STi-Mulation
Member#: 34722
05 BMX
Just a note, because of the way they are mande, i.e. trumpet like horn, they are quite a squeeze in the stock horn position. I had to flex the steel bracket of the horn to just barely squeeze it in with the 'trumpets' facing downwards.
Old 03-18-2004, 01:36 PM   #9
banman
Member#: 12408
2006 Legacy GT
Are you sure we're talking about the same ones? From the pictures, they look like disc-type horns, not trumpets . . .
Old 03-18-2004, 02:05 PM   #10
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Eh? What trumpets? Yeah, I'm pretty sure they're the disc type. One mounts in the stock '02+ location no problem, and for the other one you can use a Forester bracket or just make one...
Old 03-18-2004, 02:21 PM   #11
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
To clarify - there are two "red" coloured electromechanica Hella aftermarket horns that are being talked about here:
A. Hella supertone metal "disc" type (they look like unicron -- ie. the transformer, before he eats a planet ) from the front, and have a red-painted metal exoskeleton around it that can be removed and painted separately if you like. You can either buy the "Supertone" discs as a pre-boxed 300/500Hz pair, or separately (in which case you buy one 300, and one 350 I think)
B. Hella "trumpet" type (they look like red seashells (albeit large, seashells). I'm not sure of the construction, frequencies, and/or pair/single buy method for these, but I'm sure STi-Mulation can tell you more about them.
I have (A) and STi-Mulation has (B). Mine sound obnoxiously loud while STi-Mulation's sound (I've heard them personally) are very german/euro-like -- a nice classy tone.
BTW - both (A) and (B) are louder than stock.
For Mounting (A), I mounted both to the center beam support, and relocated the original stock horn up and towards the passenger side there's already a hole in the GD/GG front skeleton to do this) (it may or may not require a slight extension to the stock wiring to do this)
hope that clears up some of the Q's. Please correct me if I'm wrong.
have fun!
-- Dendrobium
Old 03-18-2004, 05:53 PM   #12
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Any local shops supply this or is ebay the best choice?
I think I'm going to get these as well!
fukamoto is offline   Reply With Quote
Old 03-18-2004, 07:44 PM   #13
STi-Mulation
Member#: 34722
05 BMX
Ha.. sorry for any confusion...
Basically what I got are these
And what I THINK Dendrobium has are these
http://accessory-center.com/series.p.../1154?f1=HONDA
Hope it clears things up..
Old 03-19-2004, 01:03 AM   #14
Brian Broz
Member#: 13783
2008 2.5i Slow
Don at PDM-Racing has some hellas me thinks,
Brian
Brian Broz is offline   Reply With Quote
Old 03-19-2004, 07:17 AM   #15
imprezaboi
Member#: 7382
MY01 GC8 - 4
BRP
Brian
Right on the nose.
I'd be down for a set in the not so distant future and it seems as though many others express certain interests in this as well. Maybe we could gather up a group buy? (not thinking of heading one up, just a mere suggestion)
imprezaboi is offline   Reply With Quote
Old 03-19-2004, 10:47 AM   #16
Reckon
Member#: 19216
2002 WRX Red/Carbon
USE THE SEARCH FUNCTION
aye, im interested. and im interested in how dendrobrium hooked his up
Reckon is offline   Reply With Quote
Old 03-19-2004, 01:20 PM   #17
SubaruWrex
Member#: 14661
2004 WRX Rally Blue
90 Legacy TSD'er SOLD
I too am interested in a group buy
SubaruWrex is offline   Reply With Quote
Old 03-19-2004, 01:23 PM   #18
banman
Member#: 12408
2006 Legacy GT
I just e-mailed PDM for pricing, but from what I've heard, they don't give discounts for group buys. There's a pair of Supertones on eBay that ends today for around $30US, so I'll probably go for those. However, if people do end up buying some from PDM, I'm willing to host a tech day for installs.
EDIT - Ouch! $108+tax at PDM!
Old 03-19-2004, 02:21 PM   #19
fukamoto
Member#: 13339
2014 SWP WRX Wagon
If we have a tech night to install these bad boys, I'll definately get a pair from EBay! Do you have links from where your going to buy from EBay?
If we all buy together and get it shipped to one address, we might get savings to shipping. Should we start a new thread?
Old 03-19-2004, 03:27 PM   #20
banman
Member#: 12408
2006 Legacy GT
Well, maybe I should tell you which one I'm going to bid on, so that we don't get into a bidding war :
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT
The auction ends in about five hours, so I'll let you know if I get them or not.
This seller/vendor seems to have several of these up at any one time, but I haven't seen any dutch auctions for the Hellas. If I win this bid, I'll e-mail the seller and see if he would be interested in a group buy. It says that he only ships to the States, so I was going to have them shipped to my sister in California and have her send them up.
Old 03-20-2004, 08:46 PM   #21
banman
Member#: 12408
2006 Legacy GT
Okay, here's the scoop. I missed that other auction I mentioned, but I found a dutch auction with a Buy It Now price of $44.00US ($58.30CDN at current exchange rate). There are four sets, so if we buy together we can split the cost of shipping (I can ship to my sister, unless someone has a US shipping address we can use). Here's the auction URL:
Old 03-21-2004, 01:32 AM   #22
SubaruWrex
Member#: 14661
2004 WRX Rally Blue
That ebay auction is for the 300 + 375hz horns thought right??
there's also the 300 + 500hz horns that he's selling.. but for 15 bucks more though...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2468305032
Old 03-21-2004, 01:52 AM   #23
Necromancer
Member#: 477
GC4 -> GGA -> GM6
I once did a Group Buy for Supertones at $60US apiece. Better deals can be found, dunno about customs though.
Old 03-21-2004, 12:49 PM   #24
banman
Member#: 12408
2006 Legacy GT
I don't mind getting the 300/375 set . . . but since it's the same seller, if people want to get the 300/500 set, we can still save on shipping if we get them sent together.
EDIT - Necro - $60US is exactly what the Buy It Now price is for the 300/500 set.
Old 03-22-2004, 12:39 PM   #25
banman
Member#: 12408
2006 Legacy GT
Okay, I just bought mine (300/375) . . . if anyone else wants in to cut shipping costs, better buy soon. Auction ends today (fixed price).
Help with hella supertones/hella foglight install.... Super_HKS North West Impreza Club Forum -- NWIC 18 04-24-2008 10:12 AM
('93-'01) Hella Supertone horns garface Impreza Forum 5 04-26-2001 12:57 AM
hella supertones, where to buy fast? jeffg North West Impreza Club Forum -- NWIC 5 03-23-2001 01:44 PM
Hella Supertone Group Buy! Necromancer Bay Area Impreza Club Forum -- BAIC 0 02-25-2001 10:33 AM
Hey Revision...Hella SuperTones question gtguy Mid West Subaru Owners Club Forum -- MWSOC 12 02-25-2001 05:58 AM
