Old 03-18-2004, 11:45 AM   #1
zavala
Member#: 44371
Exclamation Turbo Timer install question. PLEASE RESPOND! i need this in a hour!
ok, i bought a greddy turbo timer used from a friend, it has never been hooked up at ALL. now, i bought a HKS wire harness and i under stand how to put that in and everthing. i just don't know what to do with the grey wire comeing from the back of the turbo timer!! i want to keep my factory alarm and everything, and i know to cut the green/black wire and the grey wire next to the e-brake. but i don't know which wire to splice into the pink wire!!!! please help me!!!!
zavala is offline   Reply With Quote
Old 03-18-2004, 02:32 PM   #2
bleuquila
Member#: 31922
03 wrx wagon
78 brat
so.. there's one gray wire left over that you don't know what to do with. And you know you need a wire that will tap into the e-brake (pink or green) wire. What's the question here? just connect the two things you have leftover
seriously, that's what I'd do if there aren't real instructions out there, but I'm sure there are. I've installed a TT but it wasn't greddy.
on another note, what in the world could be so pressing about a turbo timer that you need it installed INSTANTLY? Just curious.
bleuquila is offline   Reply With Quote
Old 03-20-2004, 03:41 PM   #3
Chiznarles
Member#: 53686
if he didn't install it right now his car would blow up! OMG!!!
Chiznarles is offline   Reply With Quote
Old 03-20-2004, 08:36 PM   #4
TygerStile
Member#: 14531
02' Stage4 wrb WRX
06' Mazdaspeed6, 85' AE86
I guess he did ok, since we didnt hear back from him. Anyway, here are some turbo timer install instructions. They use a Blitz tt, but they all work the same and use the same harness...
http://www.scoobymods.com/forums/sho...ht=Turbo+Timer
TygerStile is offline   Reply With Quote
Old 04-08-2004, 09:36 PM   #5
-AliasMunky3-
Member#: 57407
1983 02WRX & 14BRZ
WRB & DGM
[Sorry to bump this old thread, but I sorta have a question or two myself.]
I just put mine in [Greddy TT w/ HKS FT-3 harness].
The brown wire goes to the E-Brake and the purple wire goes to the ECU.
I did notice one thing though.
Basically, the TT won't work if I have it hooked up to the ECU, but it WILL WORK when hooked up to everything else BUT the ECU, ie, the ignition and e-brake.
The RPM gauge on the TT works and the voltmeter for the battery as well.
My friend has the HKS Type Zero and his is hooked up to his speedometer wire for his ECU. I have the Greddy Full Auto and it isn't, but still seems to work.
-Al-
-AliasMunky3- is offline   Reply With Quote
Old 10-31-2004, 02:57 AM   #6
InfamousDX
Member#: 25413
-Al-
What wire on the ECU do you tap into? And what is that for anyway... speed?
Old 10-31-2004, 08:01 PM   #7
-AliasMunky3-
Member#: 57407
1983 02WRX & 14BRZ
WRB & DGM
This version of TT doesn't need and ECU signals (or so it seems at least) so I am actually running it strictly connected to the ignition.
It's been doing its job for about 7 months now.
The only thing is that on -H- it seems to overcount after 2hour highway trips at 75mph/3200rpms steady - goes to over 9 minutes sometimes. That's when I just preset it to about 3 minutes.
Old 01-21-2005, 03:30 PM   #8
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
Just FYI on the Greddy FAT the grey wire with the clear plastic is not used on USDM subarus.
BVM is offline   Reply With Quote
Blitz Turbo timer install question Sharky NRK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-26-2002 03:03 AM
Greddy Turbo Timer Install Question SCP5000 Normally Aspirated Powertrain 3 08-13-2002 11:35 AM
Greddy Turbo Timer Install Question SCP5000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-12-2002 07:14 PM
Turbo Timer install question kastle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-15-2002 06:28 AM
turbo timer install question skip4343 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-02-2002 04:52 PM
