Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 03-18-2004, 12:51 PM   #1
Rabidbyte
Member#: 36039
2001 Impreza 2.5RS
Lightbulb DIY/JUNKYARD FM-Intercoolers
I wanted to know peoples opinion on using a used intercooler from a truck/car. For example I came across two Isuzu NPR intercoolers on eBay. Thought to myself it would make a nice FMIC rig for any turbo application. I'm sure I'd have to find out what the CFMs are on it and compare it to other aftermarket ones. Iím reaching here, but would someone have those specs available?
Post way guys, let me know your thoughts on this.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2467702577
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2467700451
-George Ferrao
MiamiRacing.com
http:www.miamiracing.com
Rabidbyte is offline   Reply With Quote
Old 03-18-2004, 01:03 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
It isn't the IC itself that is the problem....It's the piping and the rest of the hardware that is.
If you think you can figure out the piping and all that...go for it.
Old 03-18-2004, 01:11 PM   #3
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Exactly. Sourcing a IC isnt a prob but the piping it. Also, the size of the IC should be considered since you will probably chop the bumper beam up.
Need4Boost is offline   Reply With Quote
Old 03-18-2004, 01:12 PM   #4
speedblind
Member#: 42202
You can buy new cores pretty cheap and make your own IC if you have access to a pipe bender. The other option would be to buy mandrel bent pieces separately and weld them together to make it work. If you've got the talent and the tools to do it, you can save some $$.
speedblind is offline   Reply With Quote
Old 03-18-2004, 03:22 PM   #5
SparkysJDMSpeedWagon
Member#: 52530
2004 For Sale:
Silver 04 wagon w/18g
Another popular DIY intercooler is the one from the Ford Powerstroke diesels.
http://cgi.ebay.com/ebaymotors/ws/eB...category=42604
SparkysJDMSpeedWagon is offline   Reply With Quote
Old 03-18-2004, 03:45 PM   #6
tux
Member#: 40949
2003 wrx
wr blue
don't take any from conquests or starions. they need them
tux is offline   Reply With Quote
Old 03-18-2004, 05:05 PM   #7
Blue_Rexer
Member#: 43621
2011 FXT
In all the situations I have been in where ppl have made thier own I/C's for DSM's, turbo civics, ect. it has always turned out to be more of a pain that is worth. It also cost's more money in the long run.
I used to believe making everything yourself was a good idea, but sometimes it just not worth it, like in this case...
Blue_Rexer is offline   Reply With Quote
Old 03-18-2004, 06:01 PM   #8
speedblind
Member#: 42202
Good point. My buddy had a side mount DSM intercooler on his turbo Civic that he "made" himself with various fittings, PVC and metal piping. It has always given him a tough time because the fittings keep popping off under boost.
I always thought, though, that if he took his cobbled-together creation to a good muffler shop that they could bend and weld pipes together to make a more fullproof set of piping. I guess it's just a case of having access to the right tools (which most people don't) to do the job right.
Old 05-10-2004, 01:16 AM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
maybe he needs to roll/weld a bead into them..?
Old 05-10-2004, 03:09 AM   #10
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
You really should not try to piece together your own IC unless you've got a pretty good background in automotive science or metalworking or a good grasp of some fluids concepts.
With complete used FMIC's+ piping +shortram intakes going for less than 1000, it's not really worth the time and lost power with a DIY IC job.
Basically, DIY stuff in general is only good for applications where the economy of scale is lacking. DSM's and Subaru's have tons of cheap parts available, I would only use a junkyard IC if I was say putting together a turbo MR-S kit from scratch, since the ones sold are like 10 grand.
verc is offline   Reply With Quote
Old 05-10-2004, 03:44 AM   #11
collegedropout
Member#: 42569
adds to the douchery
level round' here...
This guy from Australia made a wicked custom setup for his Forrester.
Crazy Aussies
collegedropout is offline   Reply With Quote
Old 05-10-2004, 02:02 PM   #12
Wagon Of Fury
Member#: 47982
Well, right off the bat, the endtank inlet and outlets are in the wrong position. If you are handy with metal fabrication, I suppose anything is possible, the question then becomes, s it worth it ?
Wagon Of Fury is online now   Reply With Quote
Old 05-10-2004, 02:48 PM   #13
steve
Member#: 4718
~ too
many to list
Where did you get the idea that the inlet and outlet are in the wrong position? I've built and designed a number of IC's in the past, and all I can come up with is that the pic doesn't show enough to make a decision. He could have internal diffusers for all we know.
With that said, one can make an FMIC for a WRX, it's just a lot of work. Where a Honda IC will have about 4' of piping, the standard WRX FMIC has around 6'. Here's a secret though..... If you start with a CAI, then a large part of your plumbing is taken care of right away. I learned that from the Honda world.
steve is offline   Reply With Quote
DIY 08 STi intercooler Sprayer RedefinedTR Water/Methanol Injection, Nitrous & Intercooler Cooling 14 06-11-2009 10:35 PM
DIY '08 STI Intercooler guard and lower grill ironhead1230 Interior & Exterior Modification 10 10-29-2008 08:09 PM
fm intercooler zukaelite Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-13-2006 09:28 PM
FM intercooler NeaD Normally Aspirated with bolt-on Forced Induction Powertrain 12 07-19-2004 07:18 PM
BLITZ FM Intercooler DEX_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-30-2004 03:09 PM
