Old 03-18-2004, 11:51 PM   #1
Subiemax
Member#: 30691
2013 FRS
RED
Default Water-spray and collumn washer spray?
Has anyone hooked up a water spray kit to the collumn windshield washer spray?
The plug that goes into the factory pump only has 2 wires. Has to be pos & neg.
I have a quantum racing water-spray kit, and want to hook it up to the stock wiring for the washer spray.
The kit has a switch, but to me, there would be no better place for this than stock washer spray.
Has anyone tried this?
Sounds easy.
Subiemax is offline   Reply With Quote
Old 03-19-2004, 04:10 AM   #2
Subiemax
Member#: 30691
2013 FRS
RED
Old 03-19-2004, 08:53 AM   #3
cooter
Member#: 23258
2005 STi
But when you hit your washer spray button, won't your windshield wipers come on? Most likely...
cooter is offline   Reply With Quote
Old 03-19-2004, 09:10 AM   #4
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
From what i've seen, most people just add the I/C spray button.
kbcr3 is offline   Reply With Quote
Old 03-19-2004, 09:17 AM   #5
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
--or vice-versa--you will quickly run out of water doing double-duty.
Check heresorry--won't link)
http://www.clubwrx.net/forums/showt...;threadid=53864
Subahaulic is offline   Reply With Quote
Old 03-19-2004, 10:47 AM   #6
Subahaulic
Member#: 51163
Here's another from the Cobbtuning Forum by:
AZDirtRoads
Member
Member # 678
posted 15 March, 2004 03:17 AM
I have had a home made IC sprayer for about a year now and find it to be very valuable on "warm" days in Arizona (we only say hot here when it's over ~118). I have a Wagon so I was able to build the system for a mere $16.
My problem has always been an effective switch. I wanted the stock STI switch because the fit and finish is perfect with the dash, but you have to hold the button in to spray. The STI has a relay somewhere that sprays for a few seconds each time the button is depressed. So- I have been using a rocker switch, but have on occasion left it on and forgotten about it (even ran it dry once, ouch!). I wish there was a way A-ECU could automatically trigger the sprayer like the piggyback engine management systems.
That said, in the spirit of many constituents on this board, I built an adjustable timing circuit for about $15. I based it on the very common LM-555 timing chip. The stock STI switch ($30) acts as a trigger that starts the timer and opens a 12v relay. A green LED, on the empty panel next to the spray switch, lights while it is spraying and turns off after the cycle. The amount of time can be adjusted with a potentiometer on the board, I have mine set for 6 sec burst. The whole circuit fits in a 2x3x1" enclosure and sticks inside the dash with double stick tape.
I will be happy to provide anyone on this forum with the plans and parts list if they want to build one. I am also considering putting a few together and selling them on Ebay for any turbo car with a manual IC-spray and am looking for some feedback. Anyone else come up with a timer or auto-spray that will work with A-ECU? Thanks.
Old 03-19-2004, 11:55 AM   #7
reaubideux
Member#: 33666
I have yet to build my DIY IC spray kit but its something I plan on doing before summer time but I'm considering adding a pressure switch to the kit so that when boost pressure hits a set limit it will then kick on the sprayer. This way you flip the switch to activate it and that's it. Only downside is that if you're sitting in traffic you can't spray it since you won't be hitting boost b/c you're just parked there, idling.
You can pick them up in preset limits off eBay for like 25$, IIRC. I figured I'd get like a 2psi switch so that its already spraying by the time I hit full boost.
The real dilemma I'm having is finding a bottle to fit behind the battery since I have a wagon and want to retain the rear and front wiper sprayers.
I just wanted to offer this suggestion up to people who don't want to have to push and hold a button to run the sprayer, so you can keep 2 hands on the wheel or one on the wheel, the other on the shifter.
Jay
reaubideux is offline   Reply With Quote
Old 03-19-2004, 02:10 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I'm going to grab the wiper switch thingie off the next wagon I see in the boneyard to use on my car....plug-n-play
Old 03-20-2004, 08:45 AM   #9
Subiemax
Member#: 30691
2013 FRS
RED
I never thought of that.
Oh well, I guess I'll just use a switch.
MRT Water Spray Controller - I/C Spray - Make offer RallyX13 AKIC Private Classifieds 0 05-20-2009 12:51 PM
Wimpy washer spray KineKilla Rocky Mountains Impreza Club Forum -- RMIC 19 03-07-2008 06:13 PM
Windshield washer spraying trunk specialev Interior & Exterior Modification 14 12-21-2005 09:08 PM
04 STI I/C Water Spray switch + One STi spray nozzle $30.00 shipped 03WRXMA Private 'For Sale' Classifieds 6 08-06-2004 07:05 PM
('93-'01) Windshield washer spray adjust? all4wheels Impreza Forum 6 04-07-2001 12:27 AM
