Old 03-19-2004, 01:33 AM   #1
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Default Ring and Pinion swap - Do it yourself?
I consider myself hands on. I'm setting up for a 6MT swap, and I've ordered a 3.90 gearset for the R160. I've read through the service manual on disassembling the diff, and its kinda got me spooked. the procedure is full of "Service Tools" used to insert bearings etc.
I'm wondering if anyone here has done a ring and pinion swap themselves? If so, I'm looking for some tips, and an idea of how hard it really is.
If this is something I need a service shop to do, how $$$ am I looking at?
fragment is offline   Reply With Quote
Old 03-19-2004, 09:57 AM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
I had a local driveline shop (Bill's Driveline in Manchester, NH) do it for $200. There's some shimming and such that should be done to get the best longevity out of the differential, that's best done by someone experienced.
But it's certainly possible on your own... I just wouldn't reccomend it unless you've done driveline teardowns before.
/Andrew
Kha0S is offline   Reply With Quote
Old 03-21-2004, 10:22 AM   #3
tmp
Member#: 16859
05 Lgt wgn
If you have a good driveline shop near by it may be in your best interest to let them do it for you. I have done gear and axle service for 28+ years, it is not difficult, but a 1st time install... one oversight and you get a do-over$$$$ Mike.
tmp is offline   Reply With Quote
Old 03-21-2004, 10:35 AM   #4
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Thanks for the advice. I've found a driveline shop to shorten my driveshaft, so I'll ask them about doing the gear swap too.
Old 03-22-2004, 06:19 AM   #5
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
I have heard special tools are needed for subie diffs. I called around my area before and no one wanted to touch them
mr2guru is offline   Reply With Quote
Typical cost of a Ring and pinion swap? scooby-stu Transmission (AT/MT) & Driveline 1 03-06-2006 10:29 PM
Ring and Pinion Swap spoolinsuby Transmission (AT/MT) & Driveline 19 06-05-2005 11:55 PM
Rear diff ring and pinion swap... Does it matter if its locking or not? FederalAuditor Transmission (AT/MT) & Driveline 1 02-09-2005 04:09 PM
ring and pinion swap for 92' legacy Turbo swiggy Subaru Conversions 3 02-07-2005 09:20 PM
Ring and pinion swap ebeck Transmission (AT/MT) & Driveline 1 04-12-2004 09:46 PM
