Old 03-19-2004, 12:49 PM   #1
zavala
Member#: 44371
Unhappy is my WRX missing something?
well i installed my turbo timer yesterday and everything went fine. but when i went to do the little cut and splice trick for the factory alarm, i couldn't find and box under my center console. and i took everything out and even pulled back some carpet. am i missing something here?
zavala is offline   Reply With Quote
Old 03-19-2004, 01:17 PM   #2
bleuquila
Member#: 31922
03 wrx wagon
78 brat
weird! mine was parked right next to the e-brake, bolted down real secure. You should only have to pop off the e-brake plastic trim to see it, it's real obvious. What about the alarm thing that's located by the fuse panel, could you find that one?
bleuquila is offline   Reply With Quote
Old 03-19-2004, 01:17 PM   #3
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
The box is right by the parking brake. If you don't see it, you do not have the factory alarm upgrade.
mbeach is offline   Reply With Quote
Old 03-20-2004, 11:46 AM   #4
zavala
Member#: 44371
then how would i go about makeing my car be able to lock with the keyless remote while the turbo timer is counting down?
Old 03-20-2004, 04:16 PM   #5
mbeach
Member#: 39807
Have you tried it? The upgrade is a shock sensor. Without it, you should have no troubles with your alarm going off after you lock it up.
Old 03-20-2004, 04:20 PM   #6
granteeton
Member#: 53529
if it comes from the factory with an upgraded alarm, it is by the e-brake. but if it is dealer installed, it is under the dash, next to the steering column.
granteeton is offline   Reply With Quote
Old 03-21-2004, 03:10 AM   #7
zavala
Member#: 44371
well mine has neither. i can lock and unlock my car doors with a keyless remote from subaru and i can press the panic button and it will flash and honk the horn. now, with that said. the dealership did install that stupid Cliford (sp?) alarm system in it and i had them remove it because it was a extra 700$ somethin odd dollers. i just want to be able to lock my car while the turbo timer is counting down so i don't have to sit and wait with it!
Old 03-22-2004, 07:55 AM   #8
saar
Member#: 43770
2013 Impreza WRX Lim
2001 Impreza WRX STi
Unless you have a upgraded turbo...the WRX owners manual stats that due to the cooling effency of the td04 ..a cool down period is not required.....perhaps if you are driving your car reeeeeally hard...but then again its not like you will just slam your car to a stop and hop out after a rigorous drive...
saar is offline   Reply With Quote
Old 03-22-2004, 08:33 AM   #9
mbeach
Member#: 39807
It's the efficiency of the Subaru's oil-to-water cooling system, not just the turbo that makes a traditional idle down unecessary.
If you have a larger turbo, it's good insurance and it can't hurt.
can you lock your doors with the remote while your engine is running? you should be able to. If you can (have a spare set of keys handy) then you should have no troubles.
Old 03-22-2004, 08:39 AM   #10
Scobby29
Member#: 55268
2002 Wrx
Royal Blue
i have the (DEI) Clifford matrix rsx3.5.....it comes with remote start,keyless,and security...it has 2 way confermation that works so far 1/4 mile havnt tested any further....and also built in turbo timer....and its really easy to adjust times and everything else..www.directed.com
Scobby29 is offline   Reply With Quote
Is this right or is my suspension missing something? XyKo Brakes, Steering & Suspension 6 04-17-2006 09:17 PM
MODS: Why is my "Anyone need something installed?" thread gone? mav1c Mid Atlantic Impreza Club -- MAIC 32 03-18-2004 05:06 PM
What is my car missing? (pics inside) ScreaminFast Interior & Exterior Modification 54 10-10-2003 02:20 AM
Is my WRX breaking, or just breaking in. Faiz One Newbies & FAQs 5 12-12-2001 08:48 PM
why is my wrx stink so bad, REALLY? christoph1371 Bay Area Impreza Club Forum -- BAIC 4 04-21-2001 12:24 AM
