Old 12-12-2006, 08:22 PM   #1
PGT
Member#: 57283
2014 4.7L of TT Fury
w/ 4Matic
Default question for Luke/Tire Rack about TPMS
What's the scoop on the Subaru TPMS for '07+?? Hardware based system mounted on the wheels, right? I didn't see any info on TR related to the Subaru in specific, though I've read a thread your counterpart Alex started on the MINI Cooper forums (though it's not really an issue as it's ABS based on those cars).
Sounds like the aftermarket is a bit in flux right now trying to catch up. Any solutions yet for Subaru's?
PGT is offline   Reply With Quote
Old 12-13-2006, 04:26 PM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
Subaru
An Update on Tire Pressure Monitoring Systems and Aftermarket Wheels
A direct tire pressure monitoring systems (TPMS) will be standard equipment on every vehicle sold in the U.S. after September, 2007. The criteria for TPMS standardization is that the vehicle must have only four wheels (no dual-wheeled trucks or motorcycles), and weigh less than 10,000 lbs.
Subaru has had TPMS on some American cars since 2005. Schrader sensors are used and are in stock at The Tire Rack for all Subarus up to the 2006 model year. The size of the sensor shouldn’t be a problem for many wheels, but if the valve hole is in the middle of the wheel’s barrel, the sensor will not fit properly. Wheel manufacturers are aware of the issue and are rushing to get most of their wheels TPMS-compatible.
The Tire Rack's fitment specialists have carefully determined which wheels that are currently available will be compatible with the system installed on your vehicle.
If you have any questions about the wheel you're considering, call or post your question for confirmation that it will be compatible with your TPMS.
TPMS Facts
Direct TPMS use a sensor in the wheel/tire to wirelessly relay pressure back to the driver via a display inside the vehicle. Some vehicles have a digital screen that continuously shows all four tire pressures (five if spare has sensor). Others simply flash a "low tire pressure" light on the dash. Additionally, there are two different styles of sensors for a direct system: a valve sensor and a strap/band sensor. Only valve sensors are used on Mitsubishi direct system-equipped vehicles. If you bought an aftermarket SmarTire TPMS, its sensors are held on by a strap around the barrel of the wheel.
Indirect systems work in conjunction with the ABS wheel speed sensors that “count” the number of revolutions of each tire. If the right front tire is low (25psi) it will spin faster than the left front tire (35psi). The ABS system will recognize this change and alert the driver with a flashing light and possibly a loud chime. Although no current model Subaru has an indirect TPMS, it is helpful to understand this important difference -- indirect systems do not affect the fitment of aftermarket wheels.
Luke@tirerack is offline   Reply With Quote
Luke @ Tire rack question bcristea Tire & Wheel 4 06-28-2006 10:27 PM
[email protected] Rack (or anyone) will +50 Fox 5s in 16x7 clear Subaru 4-pots? gtguy Brakes, Steering & Suspension 11 01-05-2002 01:23 PM
Questions for Luke at Tire Rack suberboy Brakes, Steering & Suspension 3 10-31-2001 12:23 PM
[email protected] Discount? Paisan Brakes, Steering & Suspension 10 08-09-2001 10:35 AM
To Luke @ Tire Rack re: WRX Wagon mclmk8d Brakes, Steering & Suspension 0 06-18-2001 06:01 PM
