Vancouver Impreza Club
Old 03-19-2004, 01:57 PM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default any grease monkeys here?
i have a dunce cap on right now... i'm trying to pull a throwout bearing from a dead clutch pressure plate and i can't get the ^%$#@! circlip off... help?
Benjamin Tang is offline   Reply With Quote
Old 03-19-2004, 02:01 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Ben - I don't know much about clutches and stuff, but I do have the service manuals for a MY01 RS - might have some info in the tranny section that you could use.
You on MSN/ICQ? I'm about to leave soon so if you can catch me on ICQ - you can find my ID in my profile, and you can probably guess what my MSN name is.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 03-19-2004, 02:48 PM   #3
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
You can either use a pair of pick tools, or an actual circlip removal tool. Either will work, but the tool will be easier to use.
Do the Subaru throwout bearings actually have circlips?!?
I wasn't aware of that.
steve is offline   Reply With Quote
Old 03-19-2004, 02:50 PM   #4
Benjamin Tang
Member#: 4496
2009 Forester
red
yes it does... it's inboard on the clutch side.
i tried all night and just couldn't figure it out
i don't recall ever having to do this on my type-r
Old 03-20-2004, 10:06 AM   #5
bender
Member#: 1839
we are "automotive technicians" not "grease monkeys"
bender is offline   Reply With Quote
Old 03-20-2004, 10:14 AM   #6
Benjamin Tang
Member#: 4496
2009 Forester
red
bender... help?
Old 03-20-2004, 10:42 AM   #7
Avenger
Member#: 1234
Didn't the WRX have a different type of clutch than the RS clutch? The one on the RS is a push type and the wrx is a pull type. I've never seen one myself.. but you said it is inside the clutch, then maybe you'll need to remove the pressure plate off the flywheel before you can remove it. I'm not sure.
Avenger is offline   Reply With Quote
Old 03-20-2004, 10:50 AM   #8
Benjamin Tang
Member#: 4496
2009 Forester
red
as stated there is just a pressure plate... there is no flywheel. i have no tools that will get the circlip off, or i'm absolutely clueless
Old 03-20-2004, 11:25 AM   #9
Avenger
Member#: 1234
Well if it is a dead pressure plate that been used long, why don't you just get a new throw out bearing too? Better to change it now than to pull it all apart again in the future.
I always change the pressure plate and the throw out bearing as a pair.
Old 03-20-2004, 01:14 PM   #10
Benjamin Tang
Member#: 4496
2009 Forester
red
the pressure plate and bearing are near new (5k kms). the plate was damaged in shipping. i would like to salvage the bearing as it's $230cdn new from the dealer.
Old 03-20-2004, 04:43 PM   #11
bender
Member#: 1839
is it a WRX??
if so, you need to take the plate off on the side of the tranny. it unscrews
then you pull out the pivot pin that holds the fork in
the fork and bearing comes out as one unit, then you can seperate it.
hope you can understand this. it's one thing to do it, and another to try and explain it
Are there any grease fittings on a WRX? palmerx141 Service & Maintenance 3 11-23-2006 03:15 PM
Hou: calling all grease monkeys (Lori's turbo install) LoriAngel Texas Impreza Club Forum -- TXIC 166 02-17-2005 10:14 PM
Are there any boost monkeys left? electronfrost Private 'Wanted' Classifieds 13 05-04-2004 07:16 PM
Grease monkey overfilled my engine, now what Dealer Xing Legacy Forum 21 05-16-2002 11:54 AM
Jiffy Lube ? Grease Monkey? Speedy? Sal Photek Bay Area Impreza Club Forum -- BAIC 15 08-30-2000 12:18 AM
