Old 03-19-2004, 03:08 PM   #1
03WREX
Member#: 38932
2003 WRX
WRB - Cobb Stg2
Default EGT Probe Wire
Can someone tell me what wire I can use to connect the probe w/ my gauge?
I purchased a VDO gauge from egauges.com but I've heard that their probes weren't that good so I bought a probe from teamrip.com. I didn't realize that the probe doesn't come w/ enough wire to hook up the gauge.
Does anyone know the specific type of wire that needs to be used? I'm assuming you can use most wires but will it effect the accuracy?
03WREX is offline   Reply With Quote
Old 03-19-2004, 03:42 PM   #2
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
That depends, If there is not a box close to the probe you can only use the same wires to connect the probe to the gauge.
This is cause a thermocouple is a junction btw two dissimilar metals, for the type K that is likely the probe in this case the metals are: Chromel and Alumel.
If you use regular copper wire then you will create 4 new junctions wich will all have differing voltages that the cold junction cant compensate for.
Go to:
www.omega.com
nick
LyveWRX is offline   Reply With Quote
Omori EGT Probe/Wire Wrapping Nat Interior & Exterior Modification 8 08-23-2007 10:01 AM
How to wire the Team RIP egt probe into the Greddy egt harness impactblue Electrical & Lighting 3 03-12-2007 08:54 PM
Wiring of EGT Probe Replacement White02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-02-2005 08:14 AM
Strange EGT problem. Blown cyl4 getting worse, or bad egt probe/wiring?? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-30-2005 09:32 PM
what wire for egt probe extension??? HS WRB-rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-07-2002 12:44 AM
