Old 03-20-2004, 11:13 AM   #1
tux
Member#: 40949
2015 fxt
bl ack
Default sti gauge low i/c fluids indicator
anyone know what is entailed in hooking up the USDM STI intercooler sprayer into wrx w/ sti gauge cluster so that the low i/c lamp comes on? is it as simple as wiring it in, or is there a resistor that has to be installed? From the looks of the schematic there should be a resistor?
i may be wrong tho. so anyone w/ info
tux is offline   Reply With Quote
Old 03-23-2004, 09:03 PM   #2
tux
Member#: 40949
2015 fxt
bl ack
guess i'll try it just hooked up and see when i get the tank in
Old 03-24-2004, 11:50 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You may have to run wiring from the sensor in the tank to the cluster because the WRX wiring harness probably does not have that wiring in it.
Old 03-24-2004, 08:41 PM   #4
tux
Member#: 40949
2015 fxt
bl ack
ya unfortunately i check and couldn't find anything
Old 07-04-2004, 03:00 AM   #5
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
I am working on this as we speak... I found that the #5 pin on the B connector is the I/C spray LED. I just need to figure out how it is wired up from here
MK19_ is offline   Reply With Quote
Old 07-06-2004, 01:55 AM   #6
MK19_
Member#: 49148
Dogs are forever in
Anyone??? I am at a standstill here...
Old 07-11-2004, 07:20 PM   #7
MK19_
Member#: 49148
Dogs are forever in
Old 07-12-2004, 06:59 PM   #8
MK19_
Member#: 49148
Dogs are forever in
Question Diagram- what is this?
OK, I found this- can anyone decipher what is inline inbetween the B5 connection and the level warning switch at the tank??
Old 07-12-2004, 07:15 PM   #9
MK19_
Member#: 49148
Dogs are forever in
It looks as if the green wire goes directly to the B5 connector and the black wire directly to chassis ground- the connectors inline appear to be the actual connectors- which my US WRX harness doesn't have. Anyone have comments on this? I am headed out to see if I can get it working...
Old 07-12-2004, 08:04 PM   #10
MK19_
Member#: 49148
Dogs are forever in
PWN3D Fuschnicaas...
Well- no go again. I hope someone can nail this down and soon.
Old 07-13-2004, 07:44 AM   #11
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
The original picture that was here was wrong, I changed it, and it is now correct.
Here is the schematic for the USDM STi cluster.
When I wired in the low level light for it, all I had to do was add a pin to B5 and run the wire from the sensor to it.
Nick
Rizzo314 is offline   Reply With Quote
Old 07-13-2004, 10:56 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
looks like a current limiting resistor in series with a LED. leds don't use 12v, or even 5v, so the resistor drops some of the extra voltage so that the led doesn't burn out. you can determine the value by knowing the voltage drop of the led and the supply voltage which will be impressed across it.
ken
Old 07-14-2004, 01:13 PM   #13
tux
Member#: 40949
2015 fxt
bl ack
the sti gauge is electro luminecent. i believe it'd run off a different voltage than an led anyways... but i'm probably wrong?
Old 07-14-2004, 05:48 PM   #14
Rizzo314
Member#: 42215
Well, apparently, I uploaded the wrong schematic. That one is for the WRX. I changed it to the correct one.
I wired the sensor into the cluster without any problems. I just put a pin in B5, ran it to the sensor, grounded the sensor and it worked.
He has a Prodrive cluster, and it might be different.
Nick
Old 07-14-2004, 06:36 PM   #15
tux
Member#: 40949
2015 fxt
bl ack
hrm now once this is straightened out, next is to find how to wire a rear dif temp sensor to the wrx dif
Old 07-14-2004, 06:41 PM   #16
Rizzo314
Member#: 42215
I need to get my car back up and running, and when I do I am going to try to use the stock temp sensor out of an STi diff and wire it into the gauge cluster. It should turn off the light, and turn on the light if the rear diff gets too hot.
Nick
Old 07-15-2004, 06:10 AM   #17
MK19_
Member#: 49148
Dogs are forever in
Rats, I knew it was wired up right? Is there any way to test that LED to see if it is bad? If it i, how would I go about replacing it? Hmmm... me and electrical in this car just aren't playin too well here as of late (AVCS, this... )
Old 07-15-2004, 07:05 AM   #18
Rizzo314
Member#: 42215
Maybe it is the low level sensor? Find a spare 12 volt bulb and wire it in instead of the cluster to see if it comes on.
Nick
Old 07-15-2004, 07:06 AM   #19
MK19_
Member#: 49148
Dogs are forever in
Shouldn't the LED light up if I take B5 and run it straight to ground? Would that work for a test?
Old 07-15-2004, 07:08 AM   #20
Rizzo314
Member#: 42215
Hmm, I guess so. But I would try the sensor as well.
Nick
Old 07-15-2004, 07:16 AM   #21
MK19_
Member#: 49148
Dogs are forever in
Rats... no LED action going directly to ground. I need to make sure the pin I put in is seated all the way (should be)... and triple check that I am in B5.
Old 07-15-2004, 08:57 AM   #22
tux
Member#: 40949
2015 fxt
bl ack
mustangkilla, are you using the usdm v8 sti cluster or the jdm v7?
Old 07-15-2004, 06:42 PM   #23
MK19_
Member#: 49148
Dogs are forever in
Prodrive STi cluster- the one in MPH
Old 07-15-2004, 07:06 PM   #24
tux
Member#: 40949
2015 fxt
bl ack
oh is it el also or is it led?
Old 07-15-2004, 09:38 PM   #25
MK19_
Member#: 49148
Dogs are forever in
It is an LED- no bulb, I already checked.
FS: OH STi Gauge Cluster - Mint, Low Mileage OneBadSS Interior/Dressup/Audio & Security 4 01-25-2008 07:11 PM
Brake light comes on and off but not low on brake fluid? IIdiceII Brakes, Steering & Suspension 5 09-13-2007 10:44 PM
little low on Brake Fluid Lawsuby1 Service & Maintenance 15 01-21-2007 02:38 PM
02-06 Sti Gauge Cluster, Low Miles! Mint! DECALFX Private 'For Sale' Classifieds 16 03-16-2006 12:05 AM
JDM Version VI gauge cluster with center diff indicator A-Spec Private 'For Sale' Classifieds 7 02-09-2004 09:10 PM
