Old 03-20-2004, 10:36 PM   #1
lupohki
Member#: 3457
2008 STi
Default Help ... getting a humming and static sound from engine bay. SOLVED
There's moderately loud noise coming from the area circled in blue. It's a constant humming sound and on top of it are some static sounds that don't fit a pattern. I can hear it when I turn the ignition half way. The engine, when started, drowns it out though. I undid my grounding kit and amp/head unit power line (in yellow) and still get the noise. I'm not sure when it started. I also have a Valentine 1 hardwired to the overhead lights, but i doubt that would be the cause. From looking at the service manual, the manifold absolute pressure sensor is located there, but I can't say that's making the noise. Any advice? Thanks.
update Asked at the STi forum and seems it's normal for the throttle controller to do that. Thanks for the suggestion Mulder!
lupohki is offline   Reply With Quote
Old 04-16-2004, 09:26 PM   #2
lupohki
Member#: 3457
2008 STi
Ok, I know exactly what's making the noise now. It's the gadget labeled as (3) in the pic below. When I disconnect it, I don't get the noise. It's either the MAP sensor or the electric throttle. The manual that I have is inconsistent in referencing what that is.
Can someone tell me what that is, and what might be causing it to buzz? Maybe it's just going bad?
Thanks.
Old 04-16-2004, 11:31 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That looks like the throttle controller for the "drive by wire" system. I don't know how much noise it's supposed to make but this may be normal. If you're concerned either take it by the dealer and ask them about it, or find another nearby STi owner to compare with (or both).
Old 04-18-2004, 11:18 PM   #4
zumnwrx
Member#: 26792
03 wrx sedan
white
my wrx hums at idle also.. but i thought it was the bov..
nice to know this is normal
edgar,
zumnwrx is offline   Reply With Quote
Old 04-19-2004, 07:10 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The WRX is not the same, no drive-by-wire module. They do make a bit of noise, but to determine if yours is normal you can do the same as I suggested above, compare with an identical car or ask your dealer.
Horrible sound from engine bay..... jmanSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 03-27-2008 01:09 AM
wailling sound from engine bay..need help mkiv Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-18-2007 06:56 PM
Squeaking, shuddering sound from engine bay after releasing clutch cnw Baja Forum 15 08-01-2007 03:57 AM
Strange sound from engine bay Danbob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-04-2005 02:59 PM
Whining sound from engine bay WRXVII Service & Maintenance 5 12-07-2002 01:46 PM
