Old 03-21-2004, 10:24 PM   #1
sneeky
Member#: 44639
STi
the 35 awaits you...
Default control unit II
alright, so i have everything hooked up as far as wiring and mounting of the defi gauges and the control unit, looks amazing in the STI!! the only problem i am having is when i turn the car off the control unit stays on. i spliced the clock wires for the control unit. the only thing i can think of is that the power wire for the clock never shuts off...since it has to keep the current time. does anyone know another power source that i can splice close to the clock that shuts off with the car? also for some reason, the gauges don't preform the closing sequence anymore. they did the first few times i tested them
chris
sneeky is offline   Reply With Quote
Old 03-22-2004, 03:50 AM   #2
samwY
Member#: 31816
tap into the handbrake light
samwY is offline   Reply With Quote
Old 03-22-2004, 07:26 AM   #3
sneeky
Member#: 44639
STi
i wish i could, but i have no idea where that's located... can you help me out with location and possibly wire color?? thanks for the help
chris
Old 03-22-2004, 08:23 AM   #4
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
Sammy meant near the handbrake.
It's actually the plug for the adjustable mirror circuit.
The wire is yellow w/ red stripe on the plug. It is a 12v switched outlet. As I recall, the Defi unit's white wire will tap in here easily.
EDIT: Oh, near the clock (we put Sammy's in the armrest). Use the wires feeding your stereo (harness).
I don't know the exact pinout for these offhand, but a testlight and a friend will make quick work of it.
On the stereo harness you will be able to find:
Ground->Defi black wire
Illumination (orange)->Defi orange wire (for lights on guages)
12v Switched (yellow) ->Defi white wire
12v Constant (red) ->Defi (yellow, I think) wire
mbeach is offline   Reply With Quote
Old 03-22-2004, 09:43 AM   #5
brunetmj
Member#: 8023
2004 2.5 RS
I might be misunderstanding this but I will give it a shot.
There are two power sources available at the clock wires. One is accessory power and the other is constant. It sounds as if you are using constant power or have constant power and accessories power flip flopped. On the side of the clock constant power is labeled BAT and accessory is labeled ACC
brunetmj is offline   Reply With Quote
Old 03-22-2004, 09:59 AM   #6
sneeky
Member#: 44639
STi
deifnately gonna check that out... thanks guys
chris
EDIT: i was also advised to connect the orange AND white wires to the ignition wire because the BF gauges need to always be lit up or you won't be able to see them... don't know if this changes any of your answers.
Old 03-22-2004, 10:18 AM   #7
mbeach
Member#: 39807
We tried that on a recommendation.
It looked ghetto.
The guages were always lit up when the key was on.
Ended up doing the illumination separately. Looks far better. Not dimmable, but the driver keeps the dash at high illum at all times anyway.
Old 03-22-2004, 07:19 PM   #8
sneeky
Member#: 44639
STi
what if i wanted to hook the control unit up to the illumination selector for the stock gauge cluster? is it possible? and could anyone supply some info on which wires would need to be sliced for the STi?? i think it would look nice if the gauges changed levels at the same time as the stock cluster!!
chris
Old 03-24-2004, 12:04 AM   #9
brunetmj
Member#: 8023
2004 2.5 RS
I am pretty sure it is possible but it depends on whether the gauge is capable of it . There are two wires that go to the hazard warning switch . Notice that it dims and brightens with the other gauges. These wires are Violet and Orange which are part of the dimming circuit . I hooked a bulb to one of those wires and it will dim with the gauge cluster (cant recall which one).
However having said that , I have tried it with other kinds of things and it will only work if the gauge itself has dimming capability . I mean have the capability of multiple levels of dimming not just dim and bright.
Old 03-24-2004, 12:10 AM   #10
brunetmj
Member#: 8023
2004 2.5 RS
I should have explained that last statemeant a bit. To get a small bulb to dim and brighten with the cluster I spiced one wire into the orange wire (or violet) and the other wire of the bulb went to ground.
Old 03-24-2004, 09:07 AM   #11
sneeky
Member#: 44639
STi
the defi bf gauges do have dimming ability, i think there are five different levels, just like the stock cluster. but it's controlled from the control unit. will that make a difference??
chris
Old 03-24-2004, 09:09 AM   #12
mbeach
Member#: 39807
Excellent!
We used the stereo harness illumination wire (which should have dimmed the guages). It lights them correctly, but wouldn't dim with the dash. We'll try this one instead.
Thanks!
Old 03-24-2004, 12:01 PM   #13
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
the defi gauges dim when you turn the headlights on and are brighter when the headlights are off.
ronaldwrx is offline   Reply With Quote
Old 03-24-2004, 01:29 PM   #14
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
It definately sounds like you wired the constant 12v and the ignition 12v wrong. The controller needs a constant 12v (like the clock) to retain it's memory. Then it needs the ignition on 12v to light the gauges only when it is on.
There is one trick though. You want to run the line to the gauges from the #2 port on the controller instead of the #1 port. This way you have control of the dimming at all times. Otherwise the controller lowers the light only 1 step when the lights are turned on, where as I lower mine to the lowest setting with the lights on.
mbiker97 is offline   Reply With Quote
Old 03-24-2004, 02:37 PM   #15
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
i thought using the #1 vs #2 port was if you had BF gauges or not .. the defi site says use output 2 for BFs output 1 for other gauges - link display can go to either ..
http://www.defi-shop.com/product/cu2/cu2_top.html
Old 03-24-2004, 02:57 PM   #16
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I was told otherwise when I bought my stuff. However I figured it out pretty quickly.
Old 03-24-2004, 03:02 PM   #17
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
if i plug my BFs in port 1 they dont function properly.
Old 09-16-2004, 02:43 AM   #18
InfamousDX
Member#: 25413
Son of a bitch this is annoying. Here's the thing. I have power to my control unit but the gauges aren't powering up.
For ease of installation, I totally cut the plastic part of the clock harness off and then my dome lights went out... great move Mike. Why did this happen? I figured that it would be easier to tap them if they were straight cut, then I could use butt connectors. I don't even need the clock plug anymore cuz my gauges are going there. Moving on...
I wired the Defi black wire to clock harness GND (ground).
Defi orange wire to clock harness LIG.
Defi white wire to clock harness ACC.
Defi red wire to clock harness BAT.
Is this right? It must be because I have power to the control unit when I turn the key but I plug in the gauges (into either port) and none of them power up. Plz help... I knew I shoulda just paid someone to do it.
EDIT:: After all was said and done... it worked out just fine
FS: **NJ** Defi BF Boost 60mm, Defi Link Display Unit & Control Unit II AWDrifter21 Tri-State Area Private Classifieds 47 05-13-2009 03:23 PM
Defi-Link Control Unit II Question for Owners DTECH-WRX Interior & Exterior Modification 2 12-27-2005 08:35 PM
WTB - Local - Defi Control Unit II Remnex North West Impreza Club Forum -- NWIC 0 11-18-2005 04:22 PM
Location of Defi Control Unit II mdefalco25 Interior & Exterior Modification 0 08-25-2004 04:12 PM
Show Me Where U Mount Ur Defi Control Unit II! Mond'z Member's Car Gallery 9 03-16-2004 05:45 AM
Message Board Statistics All times are GMT -4. The time now is 02:43 AM.
