Old 03-21-2004, 10:28 PM   #1
vsboxerboy
Member#: 38534
2002 WRX Sedan
Default Wiring Boost Gauge: Quick Question.
Im installing a second hand factory boost gauge and coming out of the boost gauge is two wires, one yellow and one black. Can i connect these two wires to two wires of the same color under the steering wheel area or is the color of the wire just coincidental. Does anyone know what these two wires are anyway that are coming out of the boost gauge? Thanks for the help.
vsboxerboy is offline   Reply With Quote
Old 03-22-2004, 12:28 AM   #2
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
Without knowing the make and features of the boost guage itself, I'd venture to guess that yellow is for switched 12v and black is a ground.
mbeach is offline   Reply With Quote
Old 03-22-2004, 12:38 AM   #3
vsboxerboy
Member#: 38534
2002 WRX Sedan
I THINK its the factory boost gauge the face of the gauge says laMco in small letters
Old 03-22-2004, 02:52 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
It's just power for the light....wire it anyway you want.
Old 03-22-2004, 08:20 AM   #5
mbeach
Member#: 39807
The easiest illumination circuit to get to is behind your stereo. It's an orange wire. It will turn on the guage's lights when you turn on your headlights. There is a dimmable circuit too, but it's not so easy to get into.
black wire ->ground
yellow wire ->orange wire behind stereo
Both wires can be tapped into the same (stereo) harness if the guage is going on the dash (pod). It'll only be a short run if you do it this way.
Old 07-12-2004, 05:54 AM   #6
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
I'm trying to wire up my Oil pressure and EGT gauge so the lights dim & adjust with everything else on the dash but they do the opposite of everything else
I turn the dimmer down the oil/egt go up when everything else is up and on the oil/egt go off.
WHAT A PAIN!
-Scott A.
Edit
Just checked scoobymods
Its a Subaru thing. I'm going to try one more thing then give up.
cky211 is offline   Reply With Quote
Old 07-12-2004, 05:57 PM   #7
Alizarin
Member#: 53769
2004 WRX JDM STi v8
IAM = 0 FTL :(
WHAT A PAIN!
-Scott A.
Edit
You should try making the circuit to reverse the switched ground to a positive illum voltage, here. I'm no electronics genius and I wired it up in a few hours using the illumination circuit behind the stereo head unit (a violet and orange wire plug). I tapped into the +12V from the clock, and grounded it to the black wire in the stereo harness. Worked out nice, and I'm currently working with a guy here where I work to rig up a pot to adjust the brightness to match my dash.
Alizarin is offline   Reply With Quote
Old 07-12-2004, 06:50 PM   #8
cky211
Member#: 31129
02 WRX MPB
Yes, I found that on Scoobymods late last night. Wish I would have read that first. I spent hours with the Wiring Service manual and a Volt meter trying to tap into the dimmer circuit only to find out it makes the gauge dim backwards. Pain in the butt turned an hour job into about 3 or 4 hours.
I just wired the gauge lights to come on with parking/headlights and if they really bother me I will try that scoobymods deal I can handle soldering that stuff up.
The thing I notice most right away is the gauge pod is close to the dash color but not perfect. Is there something like Duplicolor interior paint with a perfect match?
-Scott A.
Old 07-14-2004, 04:58 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
The spare plug on the radio harness is switched/dimmed with the cluster gauges.....2 wires. Done.
Stock turbo boost issues: few questions... dman918 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 07-08-2010 11:50 AM
Installing boost gauge: How to wire? MarylandEcstasy Electrical & Lighting 6 05-06-2006 10:03 PM
quick question on boost gauge speaker wire BlackoutWRX Newbies & FAQs 1 02-11-2006 06:22 PM
Stock boost gauge: crap?? subineer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2002 08:27 PM
