Old 03-21-2004, 10:31 PM   #1
kAn9ArOo
Member#: 2294
Exclamation help! piaa xt pro 80
i am having the worst time wit these fog lights.
i got them, installed them, and they worked for like a week.
today i opened the housing to check the bulbs and the bulbs are fine. now, i can't put the housing back together cuz these stupid lil brackets that the screws go into fell off and theyre on the inside of the housing! how am i supposed to screw them in place when they can only be secured to the screw from the outside?! damn! i wired my fog lights to the stock switch. when i press the switch i hear a click from the relay, but no power no lights! *** is going on. this is pissing me off, im about to buy stock foglights, this sucks. someone help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeee!!!!!!!!!!!!
kAn9ArOo is offline   Reply With Quote
Old 03-21-2004, 11:50 PM   #2
BlkTS02
Member#: 50142
2002 2.5TS
MBP
you'll need to remove the lens / reflector assembly to get the bracket for the screws. Read the directiona and it'll show you how to put them together (you don't remove the screws from the brackets, just loosen them enough so it'll slide together)
Did you use the stock wiring harness, or the one that came with the piaas?
Did you test the lights before finishing the install? Get yourself a test light and make sure that there's power from where you're trying to get it from. Start at the battery, trace along the power cord and check everything.
If all else fails pull it apart and start over.
Trust me, you're gonna love the lights, as well as everyone behind you. But anyone in front of you or coming towards you are gonna be blind
BlkTS02 is offline   Reply With Quote
Old 03-22-2004, 09:24 PM   #3
glepko
Member#: 19651
With fog lights??? He's got some problems with aiming if that's the case, like most red americans
glepko is offline   Reply With Quote
Old 03-22-2004, 09:29 PM   #4
idealrides
Member#: 10314
03 WRX 325hp SOLD!
06 Jeep SRT8 - 450hp
the 80 XT comes in either fog or driving beam patterns. both will blind oncoming traffic, but the driving beam will actually burn their retinas.
idealrides is offline   Reply With Quote
PIAA 80-XT Pros brucelee Car Part Reviews 1 05-19-2007 03:13 AM
piaa xt 80 pro lens???! kAn9ArOo Electrical & Lighting 2 08-21-2006 07:44 PM
anyone with piaa xt 80 pros!! kAn9ArOo Electrical & Lighting 1 03-06-2004 08:00 PM
help! my piaa xt pro 80s kAn9ArOo Electrical & Lighting 10 01-27-2004 11:12 PM
anyone have piaa xt 80 pros? kAn9ArOo Electrical & Lighting 4 01-22-2004 10:26 AM
