Old 03-22-2004, 12:12 AM   #1
Smoothe
Member#: 57813
1999 Legacy SUS
Default 99 legacy sus temp guage
I have a 99 sus, i love the car but dont know much about the model as far has performace highlights, or why the car is special(30th aniv edit). I did a search and found nothing, im inquiring about some specs, and if there is an issue with the temp guages on this model. The guage will go to 3/4 below hot, coast down to level(middle) at acceleration, or idel, and dip to 1/4 above cold. What i am saying is the guage is doing its own thing , and i dont know if it is an overe heating issue or guage problem. I have 107,818 miles on the car. Any insight would be appreciated, on specs and this guage issue.
Thank You
Smoothe is offline   Reply With Quote
Old 03-22-2004, 12:40 AM   #2
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Does it go into the red part of the temp gauge? If not I wouldn't be terribly concerned over it. It's possible the gauge could just be normally fluctuating. My XT can approach the upper 2/3rds of the temp gauge and I have not had any problems yet.
DerFahrer is offline   Reply With Quote
Old 03-22-2004, 09:13 AM   #3
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
when was the last time you did a coolant flush? a REAL flush, not just a drain and refill
iamrazor is offline   Reply With Quote
Old 03-22-2004, 10:07 AM   #4
sha_zapple
Member#: 41012
1998 Legacy L
or... it could be a simple and most probable solution. Its probably just a bad Thermostat... theyre pretty cheap and easy to replace.
also, www.cars101.com is good for general information
http://www.cars101.com/outback_archi...tback%20wagons
I beleive this is your car
sha_zapple is offline   Reply With Quote
Old 03-22-2004, 02:01 PM   #5
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
well my temp gauge stays in one spot at all times, until i was having troubles with my water pump leaking coolant and lowering the level of the coolant in the system, then I had symptoms akin to yours.
Our coolant temp sensors are at the top of the engine, it doesnt take a loss of very much coolant before the sensor is only touching hot air and steam.
i think if the thermostat was bad ( stuck open or stuck shut) it would read hot(shut) all the time or cool all the time.
try bleeding any air out of the system.
biggreen96 is offline   Reply With Quote
Old 03-22-2004, 02:14 PM   #6
ajosselyn
Member#: 36269
1999 Legacy SUS
I hate to tell you this, but thats not normal at all. On my SUS the temp gauge reading stays just below the half way mark at all times. It shouldn't move at all. I think you have a bad thermostat, which has already been mentioned before.
hope this helps.
white is the best color.
ajosselyn is offline   Reply With Quote
Old 03-22-2004, 03:19 PM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Something is definitely wrong. The temp should not fluctuate much at all. Could be a bad thermostat, electric fan, or water pump. You need to get it checked out or you could be visited by the bad head gasket fairy.
Either of you SUS guys want to part with your grille?
ss
subysouth is offline   Reply With Quote
Old 03-22-2004, 04:16 PM   #8
Smoothe
Member#: 57813
1999 Legacy SUS
Thank You for your responses,
The car is still under the warrenty i recieved, so will have it checked over, i did not think temp guages were supposed to fluxuate. Like i said turning on the heat does nothing, the temp will fall at acceleration. The temp never reaches above (H) hot, but just below it and never falls below (C) cold just a 1/4 above. As for coolant flush, i have not done one, and am not sure if the dealer did one.
Thanks
shifting problems 99 legacy sus suddenthomas Transmission (AT/MT) & Driveline 10 06-10-2010 07:26 PM
NJ 99 Legacy SUS westu37 Private Vehicle 'For Sale' Classifieds 4 11-03-2009 11:09 AM
Just purchased a 99 Legacy SUS.... BuffaloSUS Legacy Forum 11 06-24-2007 12:31 AM
Modded 99 Legacy SUS TheLegacy Private Vehicle 'For Sale' Classifieds 7 04-02-2005 10:54 PM
Stock deck for an 03 wrx in a 99 Legacy SUS? SpecK Car Audio, Video & Security 1 04-04-2003 10:05 PM
Message Board Statistics All times are GMT -4. The time now is 04:49 AM.
