Old 03-22-2004, 01:51 AM   #1
mfujie
Member#: 44373
Default pics of defi electronic boost gauge install?
Does anyone have pics of an installed Defi Link boost gauge? I'm looking for ideas on how to run the wiring, and especially where to mount the sensor (the small black box that sits in between the T-joint and the control unit).
Thanks
mfujie is offline   Reply With Quote
Old 03-22-2004, 07:34 AM   #2
sneeky
Member#: 44639
STi
the 35 awaits you...
i don't have a pic just yet, but i hooked mine up yesterday, and the instructions say to keep it away from excess heat... yet make the hose line as short as possible... so i put it next to the intake. no idea if that's a good location (any other ideas?) gonna call some shops today to see exactly where they locate them. i'll try to get pictures soon.
chris
sneeky is offline   Reply With Quote
Old 03-22-2004, 08:17 AM   #3
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
Depending on where you T-off the line, the supplied hose will reach back to the firewall.
It's going to be tough to keep it away from heat anywhere in that area, so I just (a few days ago) temporarily mounted it next to the fuel filter (where it will get good circulation from the scoop).
mbeach is offline   Reply With Quote
Old 03-22-2004, 10:02 AM   #4
sneeky
Member#: 44639
STi
where did you t-off the line? did you use the three-way they gave you or did you have to get a new one? i was looking at putting it between the fuel regulator and the intake, but the hoses are much bigger than the three-way??
chris
Old 03-22-2004, 10:15 AM   #5
mbeach
Member#: 39807
I used the supplied 3-way (sorry, no pics), on a HKS BOV. I T'd in approximately 3" from the bov. 10 second install.
The hoses in this particular car were a tight fit onto the T, I ziptied them to ensure they wouldn't blow off.
Old 03-22-2004, 10:34 AM   #6
sneeky
Member#: 44639
STi
i thought it had to come off a vacuum line from the intake, no? i'm no expert, i was just follwing directions. but if that works and has accurate readings... i'm in
chris
Old 03-23-2004, 12:55 PM   #7
mfujie
Member#: 44373
So did you guys mount it to an existing bolt?
Old 03-23-2004, 05:53 PM   #8
mbeach
Member#: 39807
I temporarily stuck it on the exposed end of the bolt that is used to tighten down the fuel filter. Put a nut on the end of the bolt to hold it on. I'll screw it to the firewall when I reroute the sending unit wires this week.
Old 03-23-2004, 07:23 PM   #9
samwY
Member#: 31816
chris
I peaked on 1.1 bar, which is accurate - I think?
samwY is offline   Reply With Quote
Old 09-03-2004, 03:40 AM   #10
wrxer12
Member#: 50259
2004 WRX
Here's my setup
wrxer12 is offline   Reply With Quote
Old 09-03-2004, 10:24 AM   #11
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I t'd the sensor off of the factory T on the stock BOV. Then I mounted the sensor to a bracket on the firewall near the brake fluid reservoir. Make sure to mount the sensor in a near vertical orientation (lines sticking straight down).
mbiker97 is offline   Reply With Quote
FS Spare tire from 04-05 WRX / defi electronic boost gauge dodgerfreak714 SCIC Private Classifieds 2 01-24-2009 06:20 PM
Greddy electronic boost gauge install QwikRex Electrical & Lighting 3 05-20-2008 05:53 PM
HR: Electronic boost gauge install. Dizzuque Mid Atlantic Impreza Club -- MAIC 3 03-18-2007 01:13 PM
Electronic Boost Gauge install Problem !? HELP PLEASE boogyman_ea Electrical & Lighting 17 05-05-2005 11:40 PM
Help: GReddy Electronic Boost Gauge Installation GOT_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 11-06-2001 06:14 PM
