#1 |
Member#: 57837
Vehicle:1998 Outback White |
Hey I'm new to this forum. I have a 1998 Outback wagon. I recently replaced the front brake pads. However, I noticed before and after the new pads were installed that the brake pedal travels too far before the brakes start to work. What can I do to get the brakes to work when the brake pedal is slightly pushed?
#2 |
Member#: 33302
Vehicle:2005 Leggy GT Sedan Brilliant Silver |
Bleed your brakes?
#3 |
Member#: 4242
Vehicle:1999 BD SUS GRN/GLD gimme Legacy TPH wagon! |
A mushy brake pedal is common to most Subarus due to the two-stage brake booster implemented. Some of this undesired trait can be alleviated with the use of stainless brakes lines to eliminate the flex in the rubber OE lines. There is also a stiffening bracket that can be installed on the end of the master cylinder to prevent flex. Of course, a good bleeding always helps as well. The most extreme step, excluding upgrading the calipers, would be replacing the booster with a single-stage unit.
ag driven by guts inside! |
| Thread Tools | |
| Display Modes | |
| FS:STi complete gas pedal & clutch/brake pedal covers. | joe r | Interior/Dressup/Audio & Security | 11 | 12-27-2009 08:08 PM |
| brake pedal is mushy halfway through the pedal travel | wrxmuch? | Brakes, Steering & Suspension | 28 | 11-13-2009 12:04 AM |
| 04 manual shift boot piece. Gas pedal, auto brake pedal and auto shifter assembly | scOOtNsOOby | Interior/Dressup/Audio & Security | 0 | 10-12-2009 10:05 AM |
| Having Brake Pedal Feel Problems | InsatiableAmos | Brakes, Steering & Suspension | 2 | 08-03-2005 12:40 PM |
| Pedal to the floor! Brake pedal that is. | elcorazon01 | Subaru Conversions | 5 | 06-21-2005 01:48 PM |
