Old 03-22-2004, 09:15 PM   #1
Takumi.wRx
Member#: 54653
2004 Impreza WRX
Rally Blue
Default Fuse tap for Boost gauge
I've been searching for quite some time and no where has really explained how to tap into a fuse into the fuse box very well. I tried for about 1 hour to figure it out plugged in the Boost gauge electrical wire into both inserts, then one and then other... even put a current meter in the darn thing and got nothing... I tried to tap the boost guage electric into 2 different fuses, the lights and the fog lamps. Nothing worked.
So I sat down and thought for a good 10 minutes. Thinking since I have a good ground it couldn't be that... then I was thinking, well could the wire have a loose connection somewhere? Nope.
Someone please help me out with this,
Takumi
Oh and by the way its a mechanical Boost gauge so yeah
Takumi.wRx is offline   Reply With Quote
Old 03-22-2004, 09:35 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Why not just tap the clock harness or stereo harness? That would be much quicker.
Calvin
cnk is offline   Reply With Quote
Old 03-22-2004, 09:38 PM   #3
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
i did the fuse box tap setup before i installed all my gauges and took the clock out ..
quantum has a pic of which to tap for what you need .. check it
http://www.quantum-racing.com/Wire_Tap_WRX.htm
ronaldwrx is offline   Reply With Quote
Old 03-22-2004, 09:44 PM   #4
Takumi.wRx
Member#: 54653
2004 Impreza WRX
Rally Blue
thanks a lot for that site... But i was wondering where i can get fuse box wiretaps... like anywhere, pep boys, NAPA, checkers, etc...?
thanks a lot,
Takumi
Old 03-22-2004, 11:36 PM   #5
Takumi.wRx
Member#: 54653
2004 Impreza WRX
Rally Blue
HAHA
I hooked it up right but the bulb is a bad one. Guess I should have checked the bulb socket for voltage... well ill go pick up a different bulb tomorrow
Thanks for all of your help though guys
Takumi
Old 03-23-2004, 01:07 AM   #6
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
Old 03-23-2004, 02:53 AM   #7
shift_chow
Member#: 37365
2003 s2000
Silverstone
How do you tap into the clock?
shift_chow is offline   Reply With Quote
Old 03-23-2004, 10:09 AM   #8
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
Old 03-24-2004, 03:42 PM   #9
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
fuse taps look ghetto expecially when a subaru tech looks in there and sees 3 of them...
i like using the 3m line taps with an inline fuse holder...
and personally, i would not go off the stereo line for anything ther than your head unit.
DISCOPOPE is offline   Reply With Quote
What wires to tap for boost gauge illuminatin hotshot172 Newbies & FAQs 9 08-06-2005 03:01 PM
Best place to tap for boost gauge on 05 STI? Inprogress Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-20-2004 02:06 PM
Best place 2 tap for boost gauge on jdm 2.0? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-20-2004 07:34 PM
Tap for boost gauge before or after IC Neil Wallerstein Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-29-2001 03:15 PM
