Old 03-22-2004, 09:36 PM   #1
idealrides
Member#: 10314
03 WRX 325hp SOLD!
06 Jeep SRT8 - 450hp
Default in a sedan, can you wire up the rear window washer?
let me explain... I bought a washer pump for a wagon and installed it on my sedan's washer tank (for an intercooler mister) and then I was about to wire it up manually but then I saw a green connector sitting right there... it plugged right in. I was surprised to find it there because i thought the sedan and wagon had their own/different wiring harnesses.
Now I assume this wire goes somewhere near the fuse box but does anyone know where I can find it? I just don't want to have to run any more wires through the firewall.
Thanks
idealrides is offline   Reply With Quote
Old 03-24-2004, 12:13 PM   #2
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default Hey!
That connector is for the 2nd washer pump. It is already wired in.
Just hit the wiper mist button and it should work both pumps.
I wired in a USDM STi sprayer switch to control my sprayer.
Let me find the thread...
awdman is offline   Reply With Quote
Old 03-24-2004, 12:17 PM   #3
awdman
Member#: 27962
2003 WRX Sedan
Default Look this over.
http://forums.nasioc.com/forums/show...hreadid=503338
The answer is yes you can do this without anymore wires going thru the firewall. All your work is under the dash! Good Luck.
Old 03-24-2004, 03:43 PM   #4
idealrides
Member#: 10314
03 WRX 325hp SOLD!
it's weird how there are conflicting reports about whether the conector under the dash will work as is, or if you really have to splice the wire right there. In either case, thats exactly what I'm lookin for.
Thanks!
Old 03-27-2004, 02:19 AM   #5
it8ezbngrn
Member#: 35590
Yes you need a switch. Go to scoobymods and look for the JDM rear widow with wiper post. It has the info you need. It is my thread. I have the JDM rear glass. You could use a push butoon switch. Wire it to ground. The wires are all there. It shows how and what kind of pump.
it8ezbngrn is offline   Reply With Quote
Old 03-27-2004, 04:50 PM   #6
idealrides
Member#: 10314
03 WRX 325hp SOLD!
I already have the STi intercooler spray switch, I'm talking about the connector to plug into the switch... someone said the connector is there under the dash and you just have to plug it in to the STi switch, someone else said you have to splice the wire out of the harness. I'll check it out and set the record straight!
Old 03-28-2004, 01:43 AM   #7
it8ezbngrn
Member#: 35590
The green plug goes to the wiper switch. Will have +12 at the plug but you will have to get the negative wire at the wiper switch to connect to your switch. That plug was for the wagons rear washer tank or the JDM sedan washer.
I know this because I have done the JDM rear glass conversion. Like I said teh mod is posted ant scooby mods. Look closely at the pictures. Ther eis and extra wire that was cut then re connected. That is your wire you need. I made a mistake, and was going to mount a pump in the rear, but then i found that there was a spot up front. Sorry I didn't understand what you were trying to say before. I also love these guys who have all the wrong answers. Like the "hit the mist button it works both pumps"- It did I'm sure for him, then he woke up.
Can You Hook Up a 6 Wire Fac Sub to a 5 Wires Set Up? AliBenn Car Audio, Video & Security 7 04-27-2007 01:54 AM
Does the rear window washer nozzle spray or stream? Airboy General Community 13 01-19-2005 09:33 AM
How much can you turn up the boost? ou812haha Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-23-2003 04:24 PM
Wiring Request: How do you wire up the Prodrive/ Hella FF1000? Romuir Electrical & Lighting 7 04-28-2003 11:07 AM
