07-31-2000, 11:38 PM | #1 |
Member#: 779
Vehicle:1998 STi Wagon White |
Stromung installation question.
I get my dual tip stromung exhaust tomorrow, so I was wondering what tools I'll need (other than ramps) to install it well. Also, will I be able to take it off and put the factory one back on for when I get warranty work done on it (my dealership people are dicks)?
08-01-2000, 05:32 AM | #2 |
Member#: 481
hey, no cussing hahaha
you'll need 14mm wrenches, and some muscles to brake the bolts loose. you might need a razor to scrape the old gasket off the centerpipe. If your dealer is really a prick, he can look at the bolts/gasket and know you swapped exhauts. congrats, and good luck. g0 |
08-01-2000, 06:38 AM | #3 |
Member#: 1077
The bolts are a pain in the ass! But after i sprayed them with WD40 it loosened easily. With the rubber straps, i used a long nail as a wedge so that it could just slide out easily from the hinge.
08-01-2000, 06:49 AM | #4 |
Guest
Member#:
I had to push the wrench I was using with this 2x4 from outside to get the bolts loose
Yeah I'm a weak bitch |
08-01-2000, 07:18 AM | #5 |
Member#: 1923
Vehicle:2000 2.5RS BRP |
The exhaust swap was a 25 minute procedure for me and I didn't have the proper tools (only 1 14mm wrench, no sockets at the time, so you can imagine the fun). I didn't even jack up the car, I drove onto 2 sandbags (1 front and 1 rear, drivers side...) to get enough clearance.
Anyway, let the car COOL of like 2 hours. You'll find the muffler canister is still warm, as is the read differential. |
08-01-2000, 08:28 AM | #6 |
Member#: 1479
W. Canada
Vehicle:1999 Impreza 2.5RS Silverthorn Metallic |
The bolts on mine were siezed (car had about 15k kms) and we had to use an impact wrench (no amount of WD40 and brute force would break em loose). Incidentally, how could a muffler void your warranty? They do wear out after awhile, just like anything else.
08-01-2000, 08:45 AM | #7 |
Frank Army
Member#: 1457
SWIC
Vehicle:1999 Outback Sport Steel Blue Mica |
I used Liquid Wrench on my MY00, and it only had 3500 miles on it at the time. I highly suggest using something like that or WD40, as to not break your hands trying to get the damn botls off.
08-01-2000, 09:12 AM | #8 |
Member#: 779
Thanks guys! Yeah I'm weak too, but my dad is going to help me, so it's all good.
08-01-2000, 09:59 AM | #9 |
Member#: 165
careful with the bolts by the catalytic converter.
mine were all rusted thru and snapped when i did the midpipe swap. gotta go to the dealership for new bolts. sux. shuman |
08-01-2000, 01:39 PM | #10 |
Worst Mod Ever
Moderator Member#: 369
SWIC
Vehicle:19 CTS-V, 18 XC90 17 GTI |
A squirt of WD40 in each rubber hanger will lube it enough to slide it right out without much effort.
Aaron (awaiting all kinds of perverted remarks on this message ) |
08-02-2000, 12:00 AM | #11 |
Member#: 779
Umm how do I get the old muffler off of the rubber hangers without hurting them???
Stromung install question | spriggan | Legacy Forum | 1 | 04-03-2003 08:45 AM |
Stromung install question | ERaab212 | Tri-State Area Forum | 6 | 10-22-2002 12:36 PM |
Stromung Install Help Needed | Joncas | Normally Aspirated Powertrain | 7 | 05-05-2001 12:00 AM |
stromung install problems | remarcable | Normally Aspirated Powertrain | 10 | 04-30-2001 06:34 AM |
Stromung installed | Snowman | Normally Aspirated Powertrain | 7 | 04-08-2001 04:46 AM |
