Old 03-23-2004, 12:18 AM   #1
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
Default 02/03 vs 04+ Suspension Myth
Hi all,
I've read countless times that the suspension for the 02/03 chassis (i.e. springs/struts) were interchangeable with the 04 and up models AS LONG as the rear strut tops on the 04's were replaced with 02/03 ones.
However recently I've purchased Tein Flex's that were on my friend's STI and they bolted right up to my WRX. This leaves me wondering...?
Uncle Ben is offline   Reply With Quote
Old 03-23-2004, 03:05 AM   #2
Razlak
Member#: 7209
2005 WRX STi
World Rally Blue
What changed in the 04's was the rear spring design. They moved to a tapered rear spring that got smaller tward the top. The mounting points for the suspension hasn't changed at all though, so as long as your springs fit your strut tops(02-03 springs, use 02-03 strut tops... 04 springs , use 04 strut tops), everything is fine.
Coilovers, since they replace everything including the strut tops usually, have no problems bolting on to any 02-04 car.
Razlak is offline   Reply With Quote
Old 03-23-2004, 12:32 PM   #3
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
yep,,,what he said
Rudy
jagcars26 is offline   Reply With Quote
Old 03-23-2004, 12:37 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
All the suspension components are interchangeable....but if you want to use the stock '04 rear springs, you have to use '04 compatible rear tops with them.
02/03 vs.04/05 vs. 06/07 GTPowered4.6l Newbies & FAQs 3 04-24-2008 08:51 PM
tech question about 02/03 vs. 04 suspension REX Tuner Brakes, Steering & Suspension 15 11-04-2004 09:33 AM
CD and frontal area differences between 02/03 vs 04+ and sedan vs wagon??? BIGSKYWRX Brakes, Steering & Suspension 17 11-03-2004 10:25 PM
The answer to my question (98-01 vs 02-03 vs 04-05) eurojax Off-Topic 21 07-02-2004 12:10 PM
03 Vs 04 Suspension differences Bakes5 Baja Forum 2 04-29-2004 02:12 PM
