Old 03-23-2004, 12:48 AM   #1
PeterJ
Member#: 14727
2002 impreza RS
Question new oil temp sender for stock gauge pack
I want to get a new oil temp sender and use it with a oil gallery plug adapter but Im not sure if the stock cheapo gauge is compatable with any of the aftermarket senders. Has anyone done this?
Im wondering if maybe the stock and aftermarket senders show different voltages for the same temp. I was originally going to turn down and re-thread my stock sender to fit into the 18x1.5 gallery plug, but wanted to check here first. Thanks
PeterJ is offline   Reply With Quote
Old 03-23-2004, 07:13 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The stock gauge isn't really cheap, it's just small.
I don't think another sensor would be compatible, the resistance vs. temp values are likely to be different.
WTB: Oem oil temp sensor for stock lamco gauges theo79 Private 'Wanted' Classifieds 0 10-23-2007 12:57 AM
Oil temperature sender for OEM gauge kit kegard Electrical & Lighting 1 10-05-2007 09:06 PM
Can you use reg oil temp sensor for OEM gauge? BeBop86 Newbies & FAQs 6 07-27-2007 05:57 AM
Can you use reg oil temp sensor for OEM gauge? BeBop86 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-27-2007 05:55 AM
Oil Temp Sensor for Perf. Gauge Pkg. Wedge Normally Aspirated Powertrain 3 12-17-2000 07:30 AM
