Old 03-23-2004, 10:17 AM   #1
the spacecowboy
Member#: 765
Default Unknown problem...help
my MY00 2.5 RS drives, but when driving around town (speeds around 25 mph), it acts like its not getting power to the wheels, it shifts to the lower gear, gets speed back up, then shift back to the higher gear, slows, and does this process over again.
If you floor it, no problem...but if you want to keep at driving around town speeds, then it continues to change gears....
Any ideas?
space
the spacecowboy is offline   Reply With Quote
Old 03-24-2004, 01:08 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
it's an automatic then? or?
Jamie
Old 03-24-2004, 01:10 PM   #3
the spacecowboy
Member#: 765
auto....my bad....
space
Old 03-24-2004, 01:29 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
hate to say it but sounds like tranny slippage? tranny issues to me...
something you may want to have inspected by a Subaru tech.... or you can just wait, it will get a lot worse before it goes completely....
hard to diagnose w/out driving the car
but yeah.. best guess is tranny 'issue"
Jamie
Old 03-24-2004, 02:33 PM   #5
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
95% sure it's tranny issue. My old 86 Aries did similar thing before the transmission went on it.
trojan9x is offline   Reply With Quote
Old 03-24-2004, 02:58 PM   #6
00RScoupe
Member#: 57535
2004 FXT
Maroon
How's your O2 sensors? I have an manual and when front sensor went bad I could barely drive the car. It kinda surged ,then would cut out, then surge, If it felt like it was going to die I could floor it and get back up to traffic speed, but as soon as I let off the gas it would act up again.
It did this for ten miles before throwing the CEL for a bad sensor. IT was kind of a catastophic instant failure. I have read that when most subies need to have their O2 changed it is much more gradual and throws the code before it becomes undrivable.
Certainly alot cheaper than tranny work.
00RScoupe is offline   Reply With Quote
Old 03-24-2004, 07:54 PM   #7
the spacecowboy
Member#: 765
00RScoupe....that sounds like it would be close to what it is....hopefully that is what it is...i know when I was replacing the turbos the o2 sensors were caked with oil....that could be the problem...hopefully...
The tranny shift good....but it could also be slippage...
keep the ideas coming....hopefully the car will be sold and I won't have to worry about it...but still ideas are good...
Thanks,
space
Old 03-25-2004, 11:27 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
any check engine lights recently? at all?
Old 03-26-2004, 08:16 AM   #9
trojan9x
Member#: 3169
never heard of an O2 sensor causing a car to shift on it's own
Old 03-27-2004, 06:05 AM   #10
squeeks
Member#: 22899
01 GM6 i think
BRP
That sounds like the tranny, probably not the o2 sensor. As far as I know, if the O2 sensor was bad, it would just throw a CEL, wouldn't affect how your car shifts.
How many miles are on the car?
What kind of driver are you?
Trannys can only take so much abuse if you drive it hard, thats why I ask.
squeeks is offline   Reply With Quote
Old 03-28-2004, 05:19 PM   #11
the spacecowboy
Member#: 765
there is 70K on the car....the CEL just came one on friday....and for the 40K I had the turbo on, I ran it pretty good.....Not full throttle 24/7, but occasionally I would get on it...
Anyhow, It doesn't matter now, I sold the car to a guy in Maine, sold it as is and told him that it could be anything...
Again, thanks for the help..
space
Unknown problem. Penguin_02 Brakes, Steering & Suspension 8 03-11-2010 08:42 PM
Unknown Problem!! Bov_Rider General Community 5 06-30-2008 12:38 PM
Unknown problem fastlanerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-19-2008 02:47 AM
Noob to suspension, unknown problem itjustWoRX Brakes, Steering & Suspension 8 03-30-2006 05:49 PM
Unknown Problem subiDru Legacy Forum 17 03-27-2006 01:38 AM
