Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 03-23-2004, 10:58 AM   #1
SASniper
Member#: 57913
Question Dual-Range Transmission
I've been reading on some Aussie 2004 Forester reviews that manual non-XT's come with a dual-range transmission. Is this true in the US? I've never seen this.
I'm guessing this is because of the lower kW's in the non-XT models???
SASniper is offline   Reply With Quote
Old 03-24-2004, 09:49 AM   #2
bluesubie
Member#: 767
04 FXT
Default Re: Dual-Range Transmission
Probably that as well as gearing. In the UK, even the base Impreza wagons come with dual range.
-Dennis
Old 03-24-2004, 10:19 AM   #3
SASniper
Member#: 57913
Thanks bluesubie
Is this a hi/lo shift leaver located somewhere? button?
Does anyone know the final gear ratios between the FXT and ones with the dual-range transmission?
Old 03-24-2004, 11:59 AM   #4
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Has nothing to do with the torque output. They come with a dual range so they're more useful in actual off-road conditions. AKA, "stump pulling."
No North American subies have come with dual-range gearboxes since maybe the Brat....
Chromer is offline   Reply With Quote
Old 03-24-2004, 12:28 PM   #5
SASniper
Member#: 57913
I was wondering about the final ratio ... thinking about revs vs speed
Old 03-24-2004, 02:28 PM   #6
bluesubie
Member#: 767
04 FXT
You can find the Aussie ratios here .
-Dennis
Old 03-24-2004, 03:43 PM   #7
SASniper
Member#: 57913
Do they make the top gear on the AT a lower ratio to offet worse fuel economy through using an AT ... or just to get lower revs for same speed (when compared to MT?)
I just don't like how high my revs are when I'm doing 70mph
Old 03-25-2004, 03:37 PM   #8
brandon
Member#: 1183
09 Legacy, 76 Mini
64 Lotus Elan, 70 Elan +2
The dual-range transmissions found on Subarus (in every market other than North America) are only found on MTs, and not ATs. The biggest concern with the DR on turbo models is that people would "drag race" while in low range. The big problem with this (as I understand it, and I haven't been able to source a cutaway yet) is that the reduction gear is on the INPUT side of the transmission. Although this keeps things very light and compact, it also multiplies the torque TO the transmission. I'm sure most of you can appreciate that this would be bad in a higher power application. It is interesting to note in support of the above, that the low range used to be much lower, before the more recent breed of engines came to be.
What is REALLY neat about the Subaru DR though, is that it is fully syncronized, and thus can be used "on the fly". Just push in the clutch at any speed, and pull the little lever. It's like having a 10spd. Try that on your Suburban! The unfortunate part about the newer DRs, is that the center is not manually lockable. I have been told that they are equipped with a slightly more aggressive viscous center to make up for it, but I can't substantiate that claim.
Incidentally, the last DR in NA was the Loyale (1994), and not the BRAT. I think the RX Turbo's transmission was the coolest Subaru ever built. AWD (as opposed to fixed 4WD), low range AND a manually lockable center differential (the only other Sube getting that was the XT6, but it didn't get DR).
brandon is offline   Reply With Quote
Mini rant: dual-range transmission in EDM models Bluefoton General Community 7 07-03-2008 04:08 PM
Dual Range brandon Transmission (AT/MT) & Driveline 20 08-22-2005 11:54 PM
wtb dual-range for forester forester_ranger Private 'Wanted' Classifieds 0 11-16-2003 03:44 AM
