Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 03-23-2004, 02:34 PM   #1
SASniper
Member#: 57913
Question FXT MT Reverse Gear
Does anyone else have a problem of shifting into reverse gear?
I do come to a complete stop before changing, yet it usually requires that I disengage the clutch then re-engage it a couple of times before it will go in.
My FXT has 9000miles, but has been this way since I first had it. I brought it with 1000miles on the clock.
It doesn't do this all the time ... maybe 7/10.
SASniper is offline   Reply With Quote
Old 03-23-2004, 02:49 PM   #2
SubaruCO
Member#: 33566
It's normal. Reverse is straight cut with no syncros so it occasionally isn't lined up correctly (the dogs are not lined up) so it won't go in. Just go back to neutral let the clutch out for a second then try again (with the clutch in of course). Don't force it.
Speaking of forcing it, FYI next time try the search function up top as this question has been answered many times. Not mad, just letting you know. Plus it's probably faster for the answer.
SubaruCO is offline   Reply With Quote
Old 03-23-2004, 04:52 PM   #3
SASniper
Member#: 57913
Thanks SubaruCO Search ... I usually do though I don't know why I didn't this time :weird:
Old 03-24-2004, 10:24 AM   #4
corndogs
Member#: 49322
2004 Forester XT
Java Pearl Black
I had the same problem, but going back into neutral did not work. I have to roll forward about 1 inch and then it goes into reverse nice.
corndogs is offline   Reply With Quote
Old 03-24-2004, 10:30 AM   #5
mgenti
Member#: 41552
2004 Forester XT
Plantinum Silver Metallic
That's usually what I do as well. Sometimes bliping the throtle helps as well.
--Mark
mgenti is offline   Reply With Quote
Old 03-24-2004, 10:50 AM   #6
SASniper
Member#: 57913
Thanks guys. I usually put it into neutral, release and re-engage clutch, then try again - but somethimes this doesn't work (even after multiple trys). I'll definitely give your solution a go.
Thanks again.
AccessPORT AP-SUB-003 for 08+ STi, WRX MT, 07-08 LGT, 07-08 FXT MT DirtySoap Engine/Power/Exhaust 6 11-09-2009 05:31 PM
How do I make my AVN 5435 switch to the reverse cam when i select reverse gear? jigga Car Audio, Video & Security 7 07-09-2006 01:44 PM
MT reverse and 1st problem Bootleg Transmission (AT/MT) & Driveline 5 12-14-2004 12:31 PM
Towing With Fxt Mt looney Forester Forum 8 03-07-2004 03:56 PM
Decreasing final drive ratio on the FXT-MT drew21180 Forester Forum 1 12-23-2003 02:54 PM
