Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 03-23-2004, 06:10 PM   #1
Member#: 57940
Default OBD & Emissions Testing
In my state the emissions test for my '98 RS is now an OBD test. My car has an intermittent misfire when it starts in damp weather and turns on the CEL light - however after several driving cycles the CEL light goes off and remains off. My question is - if the CEL light os off is there still freeze frame memory of the misfire problem in the memory? I ask since I want to pass the emissions test and want to make sure if I go for the test with the CEL light off that there won't be some stored codes in the memory that will cause me to fail the emissions test?
Should I take the fuse out to reset the memory before I go for the test?
alongtheroad is offline   Reply With Quote
Old 03-23-2004, 06:13 PM   #2
Member#: 10757
2013 BRZ Limited 6MT
CEL's will usually stay in the ECU's memory for 3 driving cycles. It's hard to say whether or not the code is still there without scanning it yourself. As for resetting the ECU, that would cause the readiness tests to not be completed and that's an automatic failure in most states that do OBD-II scanning.
cnk is offline   Reply With Quote
Please Help...failed emission test NJ-big problems-OBD??? rosesubaru Forester Forum 3 09-04-2006 09:34 PM
New OBD emissions testing is this a joke? Undepelo General Community 17 09-28-2005 10:00 PM
AccessPORT stage 1 failed OBD II emissions test! 04.SPT.WRX Engine Management & Tuning 28 01-31-2005 02:56 PM
Hi flow cats & emissions sniffer test in NJ.. SoLiDbReAkZ Tri-State Area Forum 31 02-06-2003 12:32 PM
OBD Emissions testing in Illinois? blkwag Mid West Subaru Owners Club Forum -- MWSOC 6 10-02-2002 02:44 AM
