Old 03-23-2004, 07:56 PM   #1
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Default Catless Midpipe?
Is it possible to have a catless midpipe, i.e. straight pipe, without the sensors? I was thinking of doing a straight pipe for the track and just zip tying the sensors to something under the car.
Is this possible or will it make the computer do funny things or hurt the sensors, etc.? Oh yeah, its a 2000 2.5RS.
D-Speed 2.5 is offline   Reply With Quote
Old 03-23-2004, 07:58 PM   #2
Defiantguy
Member#: 41268
2015 WRX
just have the spots for the o2 sensors made with the pipe. Then get a CEL eliminator for the 2nd o2 sensor. I just got the stromung track pipe myself.
Defiantguy is offline   Reply With Quote
Old 03-24-2004, 01:47 PM   #3
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Defiantguy is right, you definitely want that first sensor to be in place. The second sensor is merely for testing whether the cat works, but the first sensor is what the ECU uses for adjusting air/fuel ratios (except at WOT) and definitely needs to be there.
So if you use a track pipe, get one with the O2 bungs in place and just use a MIL eliminator on the rear sensor so you won't trip the CEL due to catalyst efficiency.
Shane
Warp3 is offline   Reply With Quote
Old 03-24-2004, 05:05 PM   #4
imprezza01
Member#: 37776
2001 2.5Rs
Aspen
I gutted a set of cats for a friend, pain in the a$$. But it worked, sounded hollow and was running rich. After about a week CEL came on, wired in a CEL eliminator fixed the problem and never looked back.
imprezza01 is offline   Reply With Quote
Old 03-24-2004, 08:23 PM   #5
Defiantguy
Member#: 41268
2015 WRX
running rich is a trademart of n/a subaru's. You can just hear it alot more when you have no cats.
Old 03-25-2004, 01:05 AM   #6
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Cool thanks for the input. I was thinking about getting one made. The reason I asked was because I was under the car the other day and that stock pipe is so restrictive looking compared the size of my Greddy catback section. I might just go with a premade section like the stromung though.
Old 03-25-2004, 01:23 PM   #7
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
After quite a bit of searching, I can't seem to find where I can buy the Stromung or any other catless intermediate pipes for the RS. Does anyone know where I can buy one?
Old 03-25-2004, 06:35 PM   #8
NicGordon
Member#: 24827
2008 Kia Spectra
Default booya!
NicGordon is offline   Reply With Quote
Old 03-25-2004, 09:18 PM   #9
mike270
Member#: 12863
2002 2.5RS
The midpipe on the RS doesn't have a cat does it? I thought it was a resonator that looks like a cat. The only thing a aftermarket pipe does is increase the diamater.
mike270 is offline   Reply With Quote
Old 03-25-2004, 09:20 PM   #10
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
They don't have a cat in the midpipe...it is just a resonator
CheezeWeezle is offline   Reply With Quote
Old 03-25-2004, 09:21 PM   #11
Section 8
Member#: 821
Don't hollow out the cats. By removing the material in the cats, you basically produce an expansion chamber that slows down exhaust flow, and then speeds up again on the other side when it reaches the normal exhaust diameter.
You can effectivly produce a standing wave, and at a certain RPM/RPMs this can cause excessive pressure. If you dynoed your car with a hollowed cat, it would likely have jagged spots where standing wave formation occurs.
Leave the ghetto mods in the ghetto. A cheap solution for a clogged cat is not a performance mod just because the cat "isn't there" any more.
As for the poster of the thread, your car will not run in any sort of respectable mannor with out a front O2 sensor in place.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 03-25-2004, 11:29 PM   #12
mike270
Member#: 12863
2002 2.5RS
That is what I thought.....
Old 03-26-2004, 10:54 PM   #13
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Thanks for all the help with this. By midpipe I meant the cat section between the header and the cat back. Right now I have the Borla Header and a Greddy EVO Catback and the stock cat section between the two is what I am talking about. Thanks again. Are there any other premade catless pipes?
Old 03-26-2004, 11:16 PM   #14
Section 8
Member#: 821
TWE will make anything that you want.
Tell them that Section 8 sent you.
cheeRS,
Greg
JDM downpipe, catless midpipe and rear section kbcr3 Private 'For Sale' Classifieds 34 12-17-2003 04:40 PM
IL: Need 3 or 2.5 inch catless midpipe. Shaitiger Private 'Wanted' Classifieds 2 11-08-2003 02:35 AM
Need 2.5 or 3 inch catless midpipe Shaitiger Private 'Wanted' Classifieds 2 09-22-2003 01:43 AM
Catless Midpipe HELP!!! CerealKilher Texas Impreza Club Forum -- TXIC 9 11-25-2002 12:50 PM
WRX catless midpipe roadr8cer2 Newbies & FAQs 0 11-29-2001 04:27 PM
