Old 03-26-2004, 01:37 AM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Is it worth camming my older engine?
I've got a DOHC EJ25 with just over 90,000 miles. I need to get my timing belt changed and I understand that this is a good time to install more agressive cams. how many further labor hours is it beyond changing a timing belt to swapping cams?
I'm also interested in whether it is worth it to cam a 90,000 mile engine. I'm looking at the TWE stage I cams for $690. What do you think?
whtlegacy is offline   Reply With Quote
Old 03-26-2004, 01:28 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
it's about 7 hours labor a side and then you have to re-shim them once you are done
HndaTch627 is offline   Reply With Quote
Old 03-26-2004, 09:26 PM   #3
obyone
Member#: 16523
Timing belt change is not a good time to change the cams. A head gasget change is becuase they'll already have the heads off the car.
obyone is offline   Reply With Quote
Old 03-27-2004, 12:11 AM   #4
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
the subaru mechanics manual says that changing the cams is 7-8 hour process on the DOHC engine. and what do you mean by reshim? does that have to do with adjusting the valve lash?
Is the timing belt change really not a good time? It's got to cut some hours off labor, right?
Old 03-27-2004, 01:27 AM   #5
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
whylegacy,
Installing the cams requires all the disassembly needed for the timing belt change and then the following:
* Remove the valve covers
* Remove the cam retaining caps
* Swap the cams
* Perform valve adjustment
* Reassembly
In my opinion this is a perfect time to install the cams. You're near the 109,000 mark for a valve adjustment anyway. Most shops charge a flat rate for the valve adjustment. They'd probably just charge an hour or two of labor for the cam install.
Best Regards,
Chris
FletchMY98 is offline   Reply With Quote
sti cams in hybrid build? is it worth it? ki11switch Built Motor Discussion 26 03-27-2011 11:00 PM
Royal purple engine oil is it worth it? wrxkid157 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-03-2009 07:54 PM
Project Engine, is it worth it? profall Built Motor Discussion 10 11-20-2008 04:29 PM
is it worth removing my intercooler piping and heatwrapping it? bradze Water/Methanol Injection, Nitrous & Intercooler Cooling 2 11-15-2008 04:15 PM
Is it worth upgrading my stock Morette bulbs? Orson Electrical & Lighting 43 05-17-2003 09:13 AM
