Old 03-23-2004, 09:15 PM   #1
paul25RS
Member#: 42209
2004 2.5RS
SQC #158 Silver
Default sylvania silverstar went out on me in 3 months!!!
my sylvania silverstar h1 bulb just went out in less than 3 months!!! never buying silverstars again.
paul25RS is offline   Reply With Quote
Old 03-23-2004, 09:24 PM   #2
jpaj88
Member#: 24719
They make silverstars in h1's now?
jpaj88 is offline   Reply With Quote
Old 03-23-2004, 09:53 PM   #3
paul25RS
Member#: 42209
2004 2.5RS
SQC #158 Silver
yeah, but they arent sold in stores yet.
Old 03-23-2004, 11:25 PM   #4
mouserWRX
Member#: 48960
2006 TL
Anthracite
Really? I've had mine in for more than 3 months now and they are fine. Did you accidentally touch the bulb? That can reduce bulb life. Ooh wait, well I have the Osram ones, but I still don't think it makes a difference, I just have no tint on mine
mouserWRX is offline   Reply With Quote
Old 03-24-2004, 01:19 AM   #5
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
yeah touching the bulb will shorten the life. although working with ALOT of headlights....h1's have to be the weakest bulb evAR...the filament is real fragile. it can take one good bump and break the filament. so question is: is the filament broken or is the bulb burnt out?
ATX25RS is offline   Reply With Quote
Old 03-24-2004, 07:16 AM   #6
ydant
Member#: 43447
2009 STI
The Good Grey
Bot of my lows (forget which is which) burned out at the exact same time. About 1 month after I got them. My highs (also silvers) have been burning fine for 3.
My DRL is/are turned off.
-y
ydant is offline   Reply With Quote
Old 03-24-2004, 08:01 AM   #7
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
my 9007 silverstars lasted about 16 months ..
ronaldwrx is offline   Reply With Quote
Old 03-24-2004, 08:52 AM   #8
paul25RS
Member#: 42209
2004 2.5RS
SQC #158 Silver
i took a loooooot of precaution to make sure that i didnt touch them :/ HIDs here i come.
Old 03-24-2004, 10:19 AM   #9
mouserWRX
Member#: 48960
2006 TL
Anthracite
Weird. I thought about doing HIDs, but after reading something that Daniel Stern posted about HIDs...the only way I'd put HIDs in the car is to actually buy the entire headlight, aka STi HIDs, not just some conversion kit w/ a bulb, igniter and ballast.
Old 03-24-2004, 10:41 AM   #10
bluestone
Member#: 36583
2004 WRX sedan
my 9006's lasted over a year.
bluestone is offline   Reply With Quote
Old 03-24-2004, 10:12 PM   #11
paul25RS
Member#: 42209
2004 2.5RS
SQC #158 Silver
what did he say?
Old 03-25-2004, 10:45 AM   #12
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
Old 03-25-2004, 10:49 AM   #13
mouserWRX
Member#: 48960
2006 TL
Anthracite
Hrm...there was some post that I read either on here or clubwrx.net that basically said that these kits aren't all that great. Since the housings aren't designed for HIDs, you think you can see better, but you really can't because of the way the beams are dispersing. Basically he said that the only way you will get GOOD vision from HIDs is to replace the entire housing and all, AKA buy the $1300 STi HID headlights and do a full swap in your car.
Old 03-27-2004, 02:14 AM   #14
it8ezbngrn
Member#: 35590
If you move your bulb in and out while it is on in a non projector housing it will change the pattern. This would also be the case if you put HIDs in a regular non projector housing. But I think it wouldn't matter in a projector hosing with the beam cut off and all.
it8ezbngrn is offline   Reply With Quote
Old 03-27-2004, 08:34 AM   #15
obyone
Member#: 16523
Are they as weak as H3's?
I swear, I have to change my H3's every 3-6 months because they burn out that quickly. And it doesn't matter which brand I buy.
obyone is offline   Reply With Quote
Old 03-27-2004, 08:54 AM   #16
paul25RS
Member#: 42209
2004 2.5RS
SQC #158 Silver
but arent our headlights and the sti headlights basically the same other than our bulbs and ballasts and igniters?
Old 03-27-2004, 11:58 AM   #17
mouserWRX
Member#: 48960
2006 TL
Anthracite
I do not believe so. I am not a HID expert, let me try to dig up that post.
Old 03-27-2004, 12:06 PM   #18
mouserWRX
Member#: 48960
2006 TL
Anthracite
Darn can't seem to be able to find the particular post I'm talking about, but after reading it, I decided that no $300 - $400 HID kit was worth it. To each their own though.
Old 03-27-2004, 06:53 PM   #19
Slowpoke
Member#: 19879
2004 WRX
Java Black
paul25RS - The WRX halogen reflector and the STi HID reflectors are different designs. Put simply, the halogen reflector is designed for of a halogen bulb, while the STi reflector is designed for a HID bulb. Pairing a HID bulb with a relector that is not designed for it will result in an improper beam pattern and will basically blind other drivers.
Slowpoke is offline   Reply With Quote
Old 03-27-2004, 09:32 PM   #20
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
my 9007s have been good for over a year and a half now. *knock on wood*
rock on.
gjhsu is offline   Reply With Quote
Old 03-28-2004, 12:05 AM   #21
wagonman
Member#: 971
my H3 bulbs have been in over 3 years now....Wizard Ultra Whites..nice cheap set of lights.
Jeff
wagonman is offline   Reply With Quote
My oem sub box just went out on me... Pappy Car Audio, Video & Security 3 05-15-2008 11:43 AM
hmmm, i think cyl #4 went out on me... latinskllz Normally Aspirated Powertrain 3 07-22-2004 09:59 AM
I went from 199-170 in 3 months... D.A.R.E. Off-Topic 0 09-29-2003 03:25 AM
Power Steering went out on me!!!!!!!!!!! Ahhhhhhh!! malik1 Bay Area Impreza Club Forum -- BAIC 0 09-20-2000 06:07 PM
