Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 03-24-2004, 03:07 AM   #1
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Thumbs up Just posted review and pics on iON/KVR performance 2-pieces brake rotor for the STi
Check it out guys, great product, I can't say enough good things about them.
http://forums.nasioc.com/forums/show...hreadid=527157
Buy their 2-pieces rear STi brake rotor here, or at least show some interest:
http://forums.nasioc.com/forums/show...hreadid=510965
ADDICT
JDM addict is offline   Reply With Quote
Old 03-24-2004, 05:09 PM   #2
G-force
Member#: 14104
UBER ILikeItLongAndH
ardDeepandSmoothEverSoCoo
why are the rears so much more expensive?
G-force is offline   Reply With Quote
Old 03-24-2004, 05:25 PM   #3
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
because the rear hat on the rear rotor is also the drum for the parking brakes, they can't just use an aluminum hat like the front as it would wear out too fast. They can use a steel insert on the inside, but steel is heavy, so the weight saving won't be that great. They figure out they can use a titanium insert with a friction coating. That is why it cost so much more.
If you look into it, all other company that offer a 2-pieces front rotor for the same OEM Brembo brakes set up (STi, EVO, G35, 350Z, R32/R33/R34 GTR), don't offer a 2-pieces rotor for the rear.
So Kudo for iON for figuring it out and let's make it happen guys
9 lbs per rotor is huge
ADDICT
Old 03-24-2004, 07:36 PM   #4
G-force
Member#: 14104
ok - i'm no metal expert - but why would we need a titanium insert for a parking brake lining? unless you're planning on drifting?
Old 03-24-2004, 09:35 PM   #5
iON Performance Inc
Vendor
Member#: 7673
G-force - using aluminum only for the parking brake will cause the hat to wear out. Which means that the part will not last, making it a very expensive item to replace.
The specially treated titanium is more durible and should last the lifetime of use on the car. (Also it has a higher frictional coefficient vs. aluminum).
There's quite a few reasons why we chose this route, it would be the most bang/buck method of making them. We could press in the cast iron hub into an aluminum, hat, however this would offer very little benefits other then just looks.
iON Performance Inc is offline   Reply With Quote
Old 03-25-2004, 12:26 AM   #6
Flat420
Member#: 35455
07 LGT Spec.B Stg2
How do the thermal properties of titanium compare to those of aluminum? Will the titanium effectively isolate the heat in the cast iron rotors and keep it away from the hub and wheel bearing assembly?
Flat420 is offline   Reply With Quote
Old 03-25-2004, 06:16 AM   #7
QuickSilverSTi
Member#: 51955
2004 STi - Sold
2008 GT500 650rwhp/630tq
How does your kit compare to the one from:
http://forums.nasioc.com/forums/show...hreadid=524667
Seems to be a HUGE price difference.
QuickSilverSTi is offline   Reply With Quote
Old 03-25-2004, 11:52 AM   #8
Flat420
Member#: 35455
07 LGT Spec.B Stg2
Two piece rotors vs. one piece. Apples to oranges.
Old 03-25-2004, 01:52 PM   #9
QuickSilverSTi
Member#: 51955
2004 STi - Sold
Ahh, that would explain it. I suck at the reading.
Old 03-25-2004, 02:47 PM   #10
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Two pieces vs. one piece
16 lbs vs 22 lbs, HUGE 30% weight difference.
911 Turbo to STi.
ADDICT
Old 03-25-2004, 02:57 PM   #11
Soontobe
Member#: 13432
00 SV650
Have you thought about the weight savings not REALLY being worth the $$$$?
All the weight saving is on the hat, which is towards the center of rotation. So all this means is that your acceleration will be minutely better, and handling will be minutely better because of the less unsprung weight. Either way....the price for the 2 piece rears is just.....ridiculous.
Soontobe is offline   Reply With Quote
Old 03-25-2004, 05:04 PM   #12
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
whether anything worth the $ it cost is all personal, all relative, depends on how you look at it.
Good point, but not ALL, just a big portion of it, see Russ's post here:
Originally posted by rlavalle
One reason these rotors are lighter than OEM ones is that the metal in the disk's wall is thinner than stock. IE, while they are the same thickness, the KVR rotor has more venting space inside.
More Specs:
KVR Venting thickness: 15.5mm
STi OEM Venting thickness: 12mm
Note the difference in space in the center.
Russ
Some what true, but not as small of a difference as you are thinking.
not a HUGE differences, but can't be ignore.
It is a lot of money, but for what you are getting, it is very reasonable.
What you have to know is, even though the weight saving and all the performance benefit doen't seem like a lot just from the rotors. But everything adds up. Weight saving from the iON 2-pieces rotor, aftermarket coilover and some light weight wheel can be as much as 17 lbs per corner of the car, that is a lot!! Another example is other weight saving item I did to my car, like titanium exhaust, tiny battery, remove spare tire/jack/tools....etc. My friends always make fun of me because none of them yield a lot of weight saving, but so far I took 160 lbs off my car, that is a whole person's weight
ADDICT
Old 03-26-2004, 01:28 AM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm still not sure how the aluminum hats would wear out on the parking brake. I don't know how you guys park your cars, but I bring mine to a stop, then engage the parking brake, hence there is no relative motion, no friction, no wear. I would think you could just apply the "friction treatment" (whatever that may be) to the inside of the aluminum hat (to provide additional grip while parked on a hill, for instance) and call it a day. What am I missing?
Of course, if you went that route, then JDM Addict wouldn't be able to get all excited about having titanium parking brake hubs on his car. Titanium RuLz!!
Pat Olsen
'97 Legacy 2.5GT sedan
Old 03-26-2004, 01:39 AM   #14
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
ADDICT
Old 03-26-2004, 04:33 AM   #15
G-force
Member#: 14104
Pat Olsen
my exact thought!! I'm sure they can save a few $$ by taking out the titanium...besides, there's no titanium in their front kit
Old 03-26-2004, 05:52 AM   #16
iON Performance Inc
Vendor
Member#: 7673
Patrick Olsen - aluminium does not have the right thermoproperties nor resistance to act solely for the use of the parking brake. To go with the aluminum option, we would have to cast an iron sleeve and insert that into the aluminium hat. This as explained before would offer minimial weight savings compared to what is intended here. The friction treatment also don't bond well to Aluminium.
G-force - There's no need for us to use this special method for the front rotors as there's no integrated drum parking brake in the front
Old 03-26-2004, 01:02 PM   #17
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
iON Performance Inc,
screw it, just tell me how much it is to make me a one off set, I'll go round up the cash........
ADDICT
Old 03-26-2004, 02:07 PM   #18
Soontobe
Member#: 13432
00 SV650
Like Patrick was saying though, what kind of thermo properties do you NEED. Aslongas your parking brake is used...as a parking brake, who cares? Also, as far as enough resistance/friction, you could always apply the friction coating to the aluminum.
And think of it this way JDM...it will be even lighter without the titanium
Old 03-26-2004, 02:11 PM   #19
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
True but the parking brake won't work
ADDICT
Old 03-26-2004, 02:13 PM   #20
Soontobe
Member#: 13432
00 SV650
Ah, missed the friction treatment wouldn't bond to aluminum part. Either way, there HAS to be enough friction for parking brake use.
FS: RacingBrake 2 Piece Slotted Rotors. ANY YEAR STi AWDrift007 Suspension/Brakes/Handling 6 03-29-2007 08:04 PM
iON/KVR performance 2-pieces anodize aluminum hat brake rotor (real life pics) JDM addict Car Part Reviews 92 09-22-2006 12:30 PM
Hot off the CNC! iON 2-piece front rotors for the MY05 STi <Weekend Sale> iON Performance Inc Suspension/Brakes/Handling 1 03-07-2005 12:20 PM
iON/KVR WRX 2-piece rotor blow-out (only for 2piston calipers using 294mm rotor) iON Performance Inc Suspension/Brakes/Handling 6 10-27-2004 06:49 PM
294mm Two Piece Brake Rotors For People With 4 Pot Calipers! OAKOS Automotive Vendor 'For Sale' Classifieds 0 09-04-2003 02:29 PM
