Vancouver Impreza Club
Old 03-24-2004, 02:41 AM   #1
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
Default what is the widest tire i should put on an 18x8 rim?
235/40/18 or 245/40/18
JikJak is offline   Reply With Quote
Old 03-24-2004, 02:58 AM   #2
bwco
Member#: 44137
Don't you put 285 on your White convertible ?
oooo.... we're talking about STi here.... it varies with the offset of your rims if u concern about rubbing.
There is a thread dedicated for wheel and offset for STi in the wheels section.
bwco is offline   Reply With Quote
Old 03-24-2004, 03:13 AM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
245/40 will be great on it. You could do a 35 series but I think 40 is ideal. You could probably squeeze a 255 on there but I think 245 is the way to go. What wheels did you get?
tora is offline   Reply With Quote
Old 03-24-2004, 03:41 AM   #4
tmr
Member#: 1744
'11 STi
Fuscia
What tire are you running? Usually, the manufacturer has a width range, and "ideal" width. 235's should be nice though, as depending on the tire, you'll most likely avoid ballooned sidewalls that'll contribute to "mushiness".
Cheers,
TMR
tmr is offline   Reply With Quote
Old 03-24-2004, 01:25 PM   #5
STi-Mulation
Member#: 34722
05 BMX
8.0 width Min = 215
Max = 245
Ideal width 225/235 depending on brand/type of rubber.
In order not to screw up your speedo too much, 235 you got to go with 40s and 245 with 35s.
Information from Falken, Yokohama & Bridgestone.
STi-Mulation is offline   Reply With Quote
Old 03-25-2004, 08:43 AM   #6
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
still deciding on the tires. ill probabaly go with bridgestone S03s. unless someone can recommend a better tire.
how do the yokohama avs sport compare to it?
or maybe i can get the re070s that come with the sti in other sizes?
id like the widest possibel so if its possibel to have 245s on without any problems like rubbing or ballooning then ill go with that. i did a search and there doesnt seem to be any 245/35/18 size tires. only 245/40/18 or 245/45/18. i guess 245/40/18 it is.
im waiting for my prodrive gc05fs to arrive. i wish they would hurry. still at least a month away.
as for the m. it has 275/30/20 now. the 285/30/19s started rubbing after i lowered the car.
Old 03-25-2004, 11:46 PM   #7
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Aren't the RE070s crap in the wet? I remember my dealer complaining about the demo STi in the rain because of those tires. Perhaps with less HP they are safe tires?
420WRX is offline   Reply With Quote
Old 03-26-2004, 12:02 AM   #8
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
they arent the greatest in the wet but not too bad either with the awd.
What's the widest tire i can put on my 17in Ver 7 wheels with no problem? vicdeng Tire & Wheel 2 04-05-2007 12:54 PM
Prodrive PFF7: what is the widest tire i can put on these? ohforesti Tire & Wheel 2 06-21-2006 01:13 PM
What is the widest tire I can put in the rear? Honda_WRX Tire & Wheel 8 04-02-2005 07:30 PM
What is the "fattest" tire I can put on my 17x8.5 +43 offset RIM? samwY Tire & Wheel 5 02-12-2005 03:03 AM
17x7.5 rim, what is the widest tire i can fit on these wrxracer55 Tire & Wheel 11 11-02-2003 10:10 AM
