Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 08-17-2000, 08:10 AM   #1
Member#: 1867
Post Question about 'Unorthodox Racing Underdrive Pulley ' and such
I was looking through the mod section, and aside from the rear sway bar (which I'll get to), the pully thing seems like a relatively inexpensive mod that is worth it if you don't plan on plopping a turbo into your Scoob for awhile (I really do plan on waiting till my warranty naturally runs out). Can you guys give me some info on this, like what exactly it does, and why are the people in the mod/aftermarket section so intent on telling me that no light dimming and such has been reported (can anyone tell I'm not a mechanic? hehe)?. I also want to make my hood scoop functional, any info on that (other than just unbolting the plate underneath it hehe). I tell ya, my head is spinning from reading through all this. But I did manage to adjust my fog lights, thanks to the people who helped me!
Edit: Forgot to add that I should have pics up by next week, pending the addition of my gauge pack and stuff
[This message has been edited by Fido (edited August 17, 2000).]
Fido is offline
Old 08-17-2000, 08:25 AM   #2
Member#: 1209
I think you can probably do a search in the tech discussions or general forum to get lots of info on this. Basically the "racing" pulley has a smaller diameter than the stock pulley, which means smaller circumference, which means on every revolution of the engine it will turn the alternator less which, theoretically, under heavy wattage loads, could cause light dimming. But I've never noticed any.
gumball is offline
Old 08-17-2000, 08:31 AM   #3
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
as to the benefits of the pulley, think about riding your bike. as for the gears by your feet, when you have it on the smaller, it's easier to pedal, smae thing here... but yeah, all the belts will move slower.
JGard is offline
Old 08-17-2000, 08:39 AM   #4
JP Money
Member#: 909
I just installed the U-Pulley on my 2000 RS. I already had a Weapon R intake and Stromung exhaust on it, but after adding the pulley, i definetly noticed some more top-end power. The car pulls harder and smoother at the top of the powerband. It wasnt too hard to install, just followed the mod's section. That thing was a b!tch to get off though. We had to use the force of the engine's crankshaft turning the pulley with the 22mm socket pinned to the ground to loosen the stock pulley.
I have an upgraded stereo, neon interior lights, and with the A/C on full blast, my lights were still bright as ever.
Hope this helps,
JP Money is offline
Old 08-17-2000, 08:55 AM   #5
Member#: 344
2004 Impreza WRX
Java Black Pearl
I have an Unorthodox Pulley, it's the only modification I've done to my 1999 OBS. I haven't done a dyno and don't have a G-Tech either, but my impression is that it doesn't make an immediately obvious or noticeable difference in performance. Unorthodox Racing also claims that gas mileage will go up, but my mileage fluctuates between 25 and 27 mpg, which is the same as before the pulley.
What I have noticed is that my A/C doesn't cool as effectively while sitting at idle as it did before the pulley. My suspicion is that the smaller pulley isn't supplying enough juice to power the A/C compressor. Others on the board have had mixed results with their air conditioners. Admittedly though it is a minor problem, which goes away if I rev the engine a bit while stationary. I haven't noticed any problems with headlights or any other electricity-dependent parts of the car.
IMHO, handling modifications would probably make more sense at this point than anything else. Nothing else gives you bang for the buck like a turbocharger or supercharger .
[This message has been edited by Impresario (edited August 17, 2000).]
Impresario is offline
Old 08-17-2000, 09:55 AM   #6
Member#: 1447
2000 Impreza
2001 Dodge 2500
Can you use a Turbocharger/supercharger with the Unorthodox pulley?
t.rod is offline
Old 08-17-2000, 10:22 AM   #7
Member#: 949
06 F2000
Speed Triple
you could leave the smaller pulley on if you were to add a turbo. you would have to replace it with the larger (stock) pulley to run a supercharger.
M8 is offline
HTML code is On
GC8 Unorthadox Racing Underdrive Pulley w/belts $40shipped AliBenn Engine/Power/Exhaust 4 02-09-2007 01:52 PM
FS: Black Unorthodox Racing Underdrive Pulley AWDrivin Private 'For Sale' Classifieds 8 02-09-2006 08:13 AM
Unorthodox Racing Underdrive Pulley Rio2000BE Private 'For Sale' Classifieds 3 09-13-2005 06:13 PM
FS: Unorthodox Racing underdrive pulley, 17" Yokohama Tires Orbiter Vancouver Impreza Club Forum -- VIC 10 11-21-2004 12:53 PM
Anyone here have an Unorthodox Racing Underdrive Pulley? wrx55 Vancouver Impreza Club Forum -- VIC 7 09-09-2000 01:09 AM
