Old 03-24-2004, 09:02 AM   #1
myracle
Member#: 52636
'02 REX
Default Daytime running light CEL
I disconnected my daytime running lights ( undid the harness ) and it is throwing a CEL. I was near a Subaru dealership that day and had the service manager reset the code.... 2 days later it came back on..... I haven't disconnected the battery yet... but I was just wondering if there is a "fix" for this.
No....I dont want "plug it back in" as the fix....
I will though, if I can't get the CEL gone...
myracle is offline   Reply With Quote
Old 03-24-2004, 09:07 AM   #2
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
what is the error code?
mbeach is offline   Reply With Quote
Old 03-24-2004, 10:06 AM   #3
myracle
Member#: 52636
'02 REX
Sorry.. I dunno... I didn't think to look at the reader when I was at Subaru. I'm wondering what others did for the CEL fix, if they had disconnected the DRL.
Old 03-24-2004, 10:14 AM   #4
mouserWRX
Member#: 48960
2006 TL
Anthracite
Well I had a CEL come on when I disconnected mine, but it was because I forget to tighten up the sensors that I disconnected to get my hand down there. Make sure your connections are tight for the MAF, EGT etc.
mouserWRX is offline   Reply With Quote
Old 03-24-2004, 10:59 AM   #5
myracle
Member#: 52636
'02 REX
I didnt have to disconnect anything.... except the DRL. All else is secure. There weren't any other codes on the code reader when I had it at the dealership...
Old 03-24-2004, 11:01 AM   #6
ryuwrx
Member#: 26714
2002 Spec C
LUR LUR
I never popped a cell from my headlights. Weird
ryuwrx is offline   Reply With Quote
Old 03-24-2004, 11:10 AM   #7
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
I would be absolutely astonished if you got a CEL just from unplugging your DRLs. Don't even know what could it would be. Hundreds of people have done this and I've never heard of your issue before. I think it's just a coincidence--you either unplugged something else accidentally or just happened to throw a code. Get the code read at Autozone (free) and tell us which one it is. Also, a list of other mods (especially ones recently installed) would be useful.
Joel
Zola is offline   Reply With Quote
Old 03-24-2004, 11:23 AM   #8
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
the CEL is not related to the drl. it cant be.....why would you get a "check engine light" for unplugging the drl....thats like saying changing the rims will throw a cel. maybe you disconnected something else? i would go to autozone, and get the code pulled there. they do it for free and will tell you the code. www.northursalia.com has a list of the CEL codes.
ATX25RS is offline   Reply With Quote
Old 03-24-2004, 11:23 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There is absolutely no connection between the ECU and the headlights. You cannot get a CEL just from disconnecting either the DRL dropping resistor or main control module.
Either this is coincidental or you accidentally disturbed or disconnected something else when you unplugged theDRLs.
Get the code read and post it here so we can help you further.
Old 03-24-2004, 11:27 AM   #10
brunetmj
Member#: 8023
2004 2.5 RS
You never mentioned where you disconnted the DRL's from. Was it from behind the glove box or from the engine compartment ?
brunetmj is offline   Reply With Quote
Old 03-24-2004, 11:37 AM   #11
ATX25RS
Member#: 4597
yeah if it was in the engine compartment , you may have undone the fuel pump relay....near the drl stuff
Old 03-24-2004, 11:44 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Go back and un-do whatever it is that you did to disconnect your drl's and try something different.
Old 03-24-2004, 11:51 AM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The fuel pump relay isn't in the engine compartment but there is certainly other stuff there that could cause this.
The fuel pump and main relays are next to the main DRL module by the glovebox, but if you accidentally disconnected one of those the car wouldn't run.
Old 03-24-2004, 12:36 PM   #14
ATX25RS
Member#: 4597
true....thats right nevermind now that i think of it, we did disconnect the wrong thing when we were looking for the pump relay
Old 03-24-2004, 12:51 PM   #15
myracle
Member#: 52636
'02 REX
It was in the engine compartment.... all I did was disconnect the DRL .. nothing else (wastegate solenoid, relays, etc.. ) No other codes were thrown... as I mentioned when I went to the dealership.....
Where behind the glove box can I disconnect the DRLs? Would the computer like this better -- and not throw CELS?
No other mods have been made yet.
Unplugging wiring harnesses in the engine would be a little different than changing rims, I would think Yes.. the DRL arent anything critical to the engine running, but it looks as if the relay is still connect to other wires within the scheme of things. I will get the code read again... and go from there... not much more we can do at this point I guess. In the meanwhile, I'll plug it back in and see of the CEL disappears.
Old 03-24-2004, 12:59 PM   #16
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
The ECU won't care--as stated above, it's not possible to trigger a CEL by disconnecting your DRLs. The glovebox location is the more elegant solution for getting rid of them, and also a required step if you plan to upgrade your headlights at any point.
Joel
Old 03-24-2004, 01:00 PM   #17
myracle
Member#: 52636
'02 REX
Ok..so I plugged it back in and the CEL is stil being thrown.. I am at work so I cant run out and have it reset or checked..... everything else is still fastened tight.. so all the coincidence suggestions look to be accurate... wonder what it is.. guess I will have to wait a lil while to find out...
Old 03-24-2004, 01:12 PM   #18
ATX25RS
Member#: 4597
n oother codes? you keep saying this. so you do know it was only one code, but dont knwo which one right? if you are at work and will be there for a while, just disconnect the negative terminal....let the car sit for 45 minutes...then reconnect. start the car and idle for about 10 minutes. no revving or anything...then shut down and you are good to go. code erased, ecu reset and see how that works.
Old 03-24-2004, 01:38 PM   #19
mouserWRX
Member#: 48960
2006 TL
Anthracite
I had the exact same problem pretty much. In the engine compartment, in order to disconnect the DRL you have to kind of get your hand in there to unplug it. Isn't it possible that you loosened some connectors for the MAF, EGT, etc? That's what happened to me, just make sure and tighten all of those up. I say this because that's EXACTLY what happened to me...but you never know
Old 03-24-2004, 01:39 PM   #20
mouserWRX
Member#: 48960
2006 TL
Anthracite
Or you can just disconnect the negative terminal, press your brakes for a bit and then reconnect it and then your code is reset and you can do what you want w/ your car. I hate doing that cause my mileage goes to crap for the first tank
Old 03-24-2004, 01:40 PM   #21
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I don't suggest a reset. This will only erase any codes in memory at the time but won't do anything to fix the problem, and the data you need to troubleshoot will be gone. The CEL will probably come back soon anyway if the code resets.
A reset also clears all the learned data in the ECU and forces it to begin the learning process all over again.
Leave it alone and get it scanned as soon as possible. If the condition that caused the CEL to come on does not recur, the light will go off on its own after a few driving cycles, but the code will still remain in memory as long as you don't do a reset so it can still be read.
Old 03-24-2004, 02:32 PM   #22
myracle
Member#: 52636
'02 REX
Yah..I wasnt going to do anything else until I can have it read.... as for me saying there were no other codes... well.. the reader has the screen where it shows all codes in memory and there was only one... the service manager didnt mention anything out of the ordinary about the CEL ..so I assumed it was because of the DRL.... maybe he just wasnt paying attention to what it was if the DRL wont throw a code like you are all saying.. Everything looks fastened and tight... but I wont speculate anymore until I get what the CEL is....
Thanks all
Old 03-24-2004, 04:02 PM   #23
myracle
Member#: 52636
'02 REX
Ok..went to the Zone... got a P10301 302 303 errors...
Says cylinders 1, 2, 3 misfire... but it isnt running bad... I think the service dood disconnected the wastegate cellanoid relay when I was showing him where I disconnected the DRL, but that is secure. would that cause the CEL to be thrown?
My remedies are.. check the plugs ( car is runnin fine ), vaccuum lines ( all look and feel secure ) and gas cap... eh.. ( gas cap is fine .. but dont think that it would cause the cylinders to misfire.. but then again I dunno for sure now a days..)
If the car is running fine.. would now be a good time to disconnect the battery and reset the ecu?
Old 03-24-2004, 04:29 PM   #24
ATX25RS
Member#: 4597
did you reconnect the one you disconnected? i would do that then disconnect the DRL module behind the glove box...as per www.scoobymods.com then try resetting to see if the same codes are through.....3 out of 4 cylinders cant be right....you would be at like 60 HP
Old 03-24-2004, 04:31 PM   #25
myracle
Member#: 52636
'02 REX
yah. my poor REX would be in bad shape.....
I did reconnect it and I will try resetting the ECU then.... just wanted to know if it was ok to try...... let's see what happens.. thanks ATX
daytime running light uninstall with jdm lights? bren wrx Electrical & Lighting 1 09-20-2005 09:08 AM
Question: brake light on, clock light out, daytime running light out PhoKingWRX Electrical & Lighting 2 05-22-2005 07:29 AM
('93-'01) How to remove daytime running lights on 2002 Imprezas Dr. Spud Funk Impreza Forum 9 05-08-2001 05:43 PM
Disabling Daytime Running Lights on a 2000 Legacy GT? rao Legacy Forum 16 05-04-2001 12:35 AM
daytime running light 2kGT Bay Area Impreza Club Forum -- BAIC 1 06-05-2000 05:13 PM
