Old 03-24-2004, 01:02 PM   #1
chubb
Member#: 42778
04 wrx
black
Default Crush washer for oil change
I am about to change my oil and I am going to replace my crush washer. Can anyone tell me the size of the crush washer?
thanks
chubb is offline   Reply With Quote
Old 03-24-2004, 01:10 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Subaru P/N: 11126AA000 Gasket
AFAIK...that's what you have to use...I don't think anybody has figgured out anything else.
Old 03-24-2004, 01:33 PM   #3
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
Don't forget flat side against the plug!
merlot is offline   Reply With Quote
Old 03-24-2004, 01:35 PM   #4
chubb
Member#: 42778
04 wrx
black
Do i have to get this from a dealer?
Old 03-24-2004, 01:36 PM   #5
chubb
Member#: 42778
04 wrx
black
What is the diameter of that crush washer ... in case I wanted to buy it from a non-dealer?
Old 03-24-2004, 01:39 PM   #6
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
I've always gotton mine from the dealer. Never had the part number either, just told them the crush washer. Also, another dealer near my work usually threw in a crush washer with all their oil filters.... Nice idea.
You could always order them online from subaruparts.com or subaruwrxparts.com
Old 03-24-2004, 01:43 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
chubb.....this is a Subaru part....I don't think there is a substitute....if you find one, please post it.
Old 03-24-2004, 10:03 PM   #8
Boxologist
Member#: 21118
don't beleive i've have used one yet in the 35k miles that i have owned my car for. ymmv.
Boxologist is offline   Reply With Quote
Old 03-24-2004, 10:44 PM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Who needs a crush washer when you use a Fumoto?
Old 03-25-2004, 12:12 PM   #10
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
The crush washer is a nice safety, but if you ever take your car to the quick change places(or anywhere not a dealer) they're probably going to leave it off... not that you SHOULD, i"m just saying I don't think it's 100% necessary...
mrbell is offline   Reply With Quote
Old 03-25-2004, 01:12 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
A washer should always be used....even if it is RE-used...
Old 03-25-2004, 01:27 PM   #12
chubb
Member#: 42778
04 wrx
black
okay ... i just shelled out for a subaru washer / filter. Just curious about other alternatives and b/c I hate going to a dealership ... even if it's to pick up a filter.
Old 03-25-2004, 02:34 PM   #13
hawksoob
Member#: 51978
1996 Legacy Outback
Red
If you happen to be ordering other parts, www.thepartsbin.com
Part number 94109-20000 "Oil Drain Plug Gasket"
$.47 each.
hawksoob is offline   Reply With Quote
Old 03-25-2004, 09:15 PM   #14
rick-l
Member#: 33868
2003 wrx
srp
Outer diameter = 1.035 inches
Inner Diameter = 0.8 inches
Just measured with a caliper
I used a copper washer for either a Porsche or an Audi I had laying around (dealer 20 miles away) but the Inner diameter was a little big but worked fine. My dealer wants $1.20
rick-l is offline   Reply With Quote
Old 03-25-2004, 09:33 PM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Amen
I've been using copper washers since my first oil change, when I found the OE crush one to be leaking already. I usually replace the copper washer at each oil change, I think I may have reused them once or twice. They have never leaked.
Oh, FWIW I have the gauge pack with the oil temp probe drain plug, if that makes any difference. It shouldn't, the seating surface of the plug against the pan/washer is the same.
Old 03-26-2004, 12:41 PM   #16
gavinl
Member#: 57891
2005 9-2x Aero
The inner diameter of the crush gasket is .75" according to Motormite catalog
gavinl is offline   Reply With Quote
Old 03-27-2004, 11:11 AM   #17
Rickyh
Member#: 40453
i have never used or reused the crush washer. i think i tossed it with my first oil change and i never did replace it. i have 33k on mycar and no leaks yet.
Rickyh is online now   Reply With Quote
Old 03-27-2004, 03:34 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
Well Ricky.....I guess that's why there's usually at least 2 ways to do things...
If ya weren't supposed to use one, Subaru wouldn't have wasted the $$$ on putting one there.
I don't know about anybody else, but having all the oil leak out of my engine because I didn't use a washer is NOT the way I want to blow up MY motor....
Old 03-28-2004, 08:43 AM   #19
orndog
Member#: 34670
2013 No gears!
Saltine American
Used to run a maintenance shop. They make copper crush gaskets in that size available through a number of vendors.
orndog is offline   Reply With Quote
Old 03-30-2004, 12:18 PM   #20
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
Every time I *don't* use one, I get leaks at the plug.
Strangely enough, when the dealer did an oil change recently (while doing the clutch shudder TSB), they didn't use one. It didn't leak, although I think a gorilla was running the wrenches that day.
So, this past weekend I'm thinking 'Hey, Subaru of Gwinnett didn't use one, so I should be safe, too.'
Wrong. Silver-dollar sized drippage after 8-10 hours. Ugh...off to order some. Did I mention the dealer kept my old one?
Scott
sdecker is offline   Reply With Quote
Old 03-30-2004, 12:56 PM   #21
Rickyh
Member#: 40453
hahaha, that is funny. a massive gushing oil leak that drains the crankcase so quick that i blow the motor. i haven't used the crush washer since day one. i have no leaks. not one drop.my car is always parked in the same spot so i would know. i check my oil weekly and it is always fine. did i tell anyone else to do it? no. i have changed the oil 12 times since i got the car and i just don't feel the need to use it. (i actually dropped it in the pan i was using at the first oil change and didn't feel like fishing it out) if it ever starts to leak, i'll get the washer and i'll let you know so you can laugh and gloat at me.
Old 03-30-2004, 09:06 PM   #22
Boxologist
Member#: 21118
why is there a crush washer there: to insure a seal.
why wouldn't it seal? maybe ur oil pan isn't truely flat causing a gap between the bottom of the head of the bolt and ur oil pan.
mine is flat appearently. if i develop a leak from there i will go to a crush washer.
Old 04-01-2004, 05:10 PM   #23
leecea
Member#: 37359
2003 WRX
Yes, the crush washer wouldn't be needed between two perfectly flat surfaces, but it will make a seal by deforming under a relatively low load when the surfaces are not perfectly flat. Without the washer, you may be tempted to overtighten the bolt if there is a small leak. Think of it as very cheap insurance against a leak or a stripped pan/bolt.
leecea is offline   Reply With Quote
Old 04-01-2004, 06:14 PM   #24
Rickyh
Member#: 40453
i just ordered a fumoto valve. what a neat little gadget.
Old 04-02-2004, 06:18 PM   #25
bowenx
Member#: 6439
2002 Impreza WRX
I use them,
One of my visits to the dealer many months ago, I just picked up like 4 from them, don't recall what they cost..
This last oil change, I picked up a gasket from CarQuest
I picked up 2, as wasn't positive about the size, think that the one that fit was 20mm?
both together maybe was $0.60?
The one time that I didn't use one, had a small slow drip, drove me nuts!!
bowenx is offline   Reply With Quote
Crush Washers (Free) for oil changes Hank3 Accessories & Misc 2 04-08-2007 11:56 PM
crush washer for oil pan moojamboo Service & Maintenance 22 02-12-2003 08:32 PM
Crush Washer - first oil change Peaty Newbies & FAQs 0 08-04-2002 04:45 PM
Crush washers from oil pan ok for Tranny pan? HomerJay Normally Aspirated Powertrain 2 07-14-2001 04:24 PM
Need to buy crush washers for oil change, where? Necromancer Bay Area Impreza Club Forum -- BAIC 7 08-06-2000 08:50 AM
