Old 03-24-2004, 01:10 PM   #1
PowerMatt
Member#: 45549
2008 Impreza 2.5i
Default 1996 Legacy fuse box layout
I own a 1996 Legacy GT that happens to be missing the cover for the interior fuse box. So I have no idea what's what in there. Would anyone know where I could find the layout for it, or would anyone be kind enough to take a picture of the interior fuse box layout on their Legacy?
The reason I ask is because I'm looking at putting a ham radio in my car. I'd like to make sure that the power outlet is on a fuse greater than ten amps, because my radio pulls a max. of 11 amps. The power outlet puts out plenty of voltage (I measured it at about 14.4 volts with the car running), and I'd like to explore this option before diving into a project to directly wire the radio to the battery.
PowerMatt is offline   Reply With Quote
Old 03-24-2004, 05:59 PM   #2
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
Here's one from my '97. I don't know if the '96 is different. Ignore the red wire and the terminal- that's an add-on I did for some CB radio power.
-Brian
KD7000 is offline   Reply With Quote
Old 03-24-2004, 06:00 PM   #3
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
And here's the cover:
Old 03-24-2004, 06:13 PM   #4
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
Oh, if you do decide to go direct to the box, that slot where I put the 7.5A fuse and the terminal is unswitched power- always on. I had meant to wire it to a switched fuse, but I forgot to test it, then I just got lazy and didn't bother to re-do it
-Brian
Old 03-26-2004, 12:03 PM   #5
PowerMatt
Member#: 45549
2008 Impreza 2.5i
Very nice, thanks. Slow reply I know, for some reason I wasn't e-mailed.
I guess the power outlet is the one marked "cigar/mirror". 20 amps will work nicely.
Old 03-26-2004, 02:18 PM   #6
PowerMatt
Member#: 45549
2008 Impreza 2.5i
I went out and took a look at my fuse box, they're pretty much the same with a couple of differences. The fuse blocks that are marked as empty have fuses in mine, and the radio is on a ten amp fuse where it says a 15 amp fuse should be.
building a fuse box, what fuses for what?? traction issuez Electrical & Lighting 3 05-27-2009 11:42 PM
Fuse Panel layout (kick panel) 94Z1LE Electrical & Lighting 3 10-30-2006 12:28 PM
HELP! - Need fuse box diagram for 91 Legacy Ti (JDM model) seowitz Legacy Forum 1 07-06-2005 01:28 PM
Fuse boxes on '93 legacy? mch Legacy Forum 6 11-09-2003 10:52 AM
Legacy fuse box info. gened1 Legacy Forum 0 08-02-2003 01:32 PM
