Old 03-24-2004, 02:33 PM   #1
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
Default JDM vs USDM swap - Emissions Issues
Hey everyone. Like most, I've gotten bitten by the EJ20 bug. I've been sick with it for quite awhile, and am just about to come into some money (finally).
I want to get a front clip, but USDM ones seem much more expensive than JDM ones. If I were to do a JDM swap (with help of several Subie guys from here who have done EJ207 swaps), what would happen when I take it to get emissions tested? What can I do to pass emissions? I don't want to do the swap, and then not pass DEQ, etc, etc.
Does it make more sense to just do a USDM swap??
Thanks
-Ben
Soon2BturbodRS is offline   Reply With Quote
Old 03-25-2004, 02:59 AM   #2
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
bump
Old 03-25-2004, 03:38 AM   #3
joehack98
Member#: 53243
I wish I could help, but I would venture a guess that It isnt legal because its JDM and never produced here in that form. But I am sure you can get away with it on the sniffer if you hook up the standard smog equipment.
-and no disrespect to this board, but is there a more active subaru conversion forum.
joehack98 is offline   Reply With Quote
Old 03-25-2004, 04:06 AM   #4
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
This board is pretty active... must be because many of us are on spring break and have better things to do than Subarus
-Ben
Old 03-25-2004, 11:28 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um...
how is $2-3000 more than ~$5-7000? for a 207
emmissions: depends on the state.. and year of car .. with a 99 .. get the usdm
Old 03-25-2004, 03:07 PM   #6
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Originally posted by Jaxx
um...
I'm not sure where you got the first statement but...
I'm just wondering if I can get away with a V4/V5 swap in my '99... Are there any loopholes?
-Ben
Old 03-25-2004, 05:20 PM   #7
grnlantern1
Member#: 2589
1998 GC8 Do-Luck
Acadia Green Metallic
You just need to Register in Yamhill County... This is where I'm from and there's no Emmisions...I did have Specialty Subaru do a Sniff check on mine when they fininshed the install and it was passing fine....I'm not sure if Portland does OBD checks or not but what I found is that if a Generic OBD Scanner is used on a JDM Engine it won't register the Computer...My Situation " I was trying to use a Snap On OBD Scanner and it wanted certain digits from my Viin Code and when I entered them the Scanner said it could not detect CPU" But when I had the Subaru dealer use there OBD Scanner it registered as a 2.0 Turboo and all functions work 4.0....So it's this is my situation so hope this helps you out a little to make your descision...I'm not sure if the USDM Engines work that way or not fo the OBD system....
Ron
grnlantern1 is offline   Reply With Quote
Old 03-25-2004, 11:24 PM   #8
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
um...
Jaxx, my motor was had for $4000 shipped... I have seen USDM STi motors go for as high as $6000 and none as low as your $2000-3000 figure. Maybe a USDM WRX motor...
Soon2B... if you can get a JDM setup, do it. You won't be disappointed. And, NO, they are not harder to get parts for... the internals are totally compatible with high-end aftermarket WRX parts and there are options for the engine management available. If you go later than a version 6, be prepared for some excessive wiring issues.
Kreeger is offline   Reply With Quote
Old 03-26-2004, 04:26 AM   #9
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
I'm thinking Version IV or Version V... I can get ahold of full front clips for $2300 shipped (V4) or $2800 shipped (V5) ... These are the same guys Sport Compact Car mag buys a lot of their motors from. Pretty reputable.
-Ben
Old 03-26-2004, 10:27 AM   #10
grnlantern1
Member#: 2589
1998 GC8 Do-Luck
It's easier to do if you try to get an Engine that works with your Year vehicle...You still have to re wire stuff but it makes it simplier..That's why I got the Version IV...I had about 30 Wires that had to be rewired but everything works good....
Ron
Old 03-26-2004, 10:45 AM   #11
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Soon2B.. good choice in a conversion. Should be a somewhat easy swap as greenlantern has stated. Your car is screaming for it and you will be surprised how many people are shocked when they find out your car is actually a 300+hp monster in disguise
You should have Jeff Sponaugle at PDX WRX tune your car... he can eek out the hidden hp of JDM STi motors better than most. Your motor will have the potential for 350-400 Whp with upgrades only to the turbo and injectors.
Good Luck!
Old 03-26-2004, 01:24 PM   #12
jeffg
Member#: 2958
2001 WRX (GC8)
So the summary of this convo then is... any city that uses an OBD emissions test, will not work with a JDM engine becuase it cant find the ECU?
Obvioulsy a sniffer only test would be fine.
I unfortunately live in a OBD2 emssions county and therefore cant do a JDM swap and still pass emissions. Right?
J
jeffg is offline   Reply With Quote
Old 03-26-2004, 02:33 PM   #13
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Kreeger - Yep! That is my thought exactly. The OBS would be an amazing sleeper ... And yes, Sponaugle knows how to tune JDM ECUs like nobody's business. The wealth of information (and people with incredible knowledge) is so damn humongous here in the PacNW that help shouldn't be a problem.
I just need to make sure I can make it emissions legal...
-Ben
Old 03-26-2004, 03:39 PM   #14
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Being relatively close to Portland, I planned on having them tune my car as well... I asked them in an email if they could make my car emissions legal for Washington and their reply was 'yes'. I am running a catless setup at this time and also, my car will not need to be actually tested until 2008, so I have plenty of time to do something about it.
Do the swap, man! Then we could form a NW sleeper wagon club!
Old 03-26-2004, 08:11 PM   #15
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
i'm working on it
Old 03-26-2004, 10:03 PM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
thats what i am talking about exactly .. and it WILL pass emmisions unlike any of the others (save the usdm sti) in a state that does obd-2 diagnostics
Old 03-26-2004, 10:32 PM   #17
Delicious Tuning
Member#: 1990
For California Emissions you need the USDM Harness as it has a lot more fuel wires for sensors and a few other things for emissions that the JDM harness does not. We all know Cali is the worse so if you go with the USDM WRX harness then you should be all set.
Cheers,
Bill
Delicious Tuning is offline   Reply With Quote
Old 03-27-2004, 10:28 PM   #18
spiralsmurf
Member#: 16085
2005 STi
Bill-
I know its somewhat pointless and will probably end up being more expensive unless you get a good deal, but can a ver 4 or 5 sti motor be run using the usdm ecu and harness.
spiralsmurf is offline   Reply With Quote
Old 03-28-2004, 05:04 PM   #19
Jon [in CT]
Member#: 2992
02 WRX Sedan
If you're getting a JDM engine and ECU and you need to pass an IM240-type emissions test on a 1996 or newer car (where they hook up a scan tool to the OBD computer), then you'll need a JDM Ver7 or later ECU. The earlier JDM ECUs (Ver4, e.g.) don't support OBD-II.
http://forums.nasioc.com/forums/show...hreadid=506043
Jon [in CT] is offline   Reply With Quote
Old 03-30-2004, 09:05 PM   #20
TRCWRX
Member#: 46037
2002 WRX EJ207
Silver CF Hood FMIC
Well thats a load of my mind possibly? I have a 2002 USDM WRX with a 2002 E207 STi JDM swap and I am in NJ the state trying to copy all of Cali's emision laws! I was worried about the OBD testing at spot inspections cause I know I will get hit sooner or later? That and I just got a APS exhaust with cat so I don't get hit with the major fine for not having one.
I had Rallispec do the swap for me as I couldn't come up with a JDM ECU. They did an incredible job on the swap and the difference in drivability between these 2 engines is incredible. May be a bit in the 6MT too that makes it more fun to drive too.
Now I have to go to my friends shop and run it on the Inspection machine to see if it comes up as a pass or not just to make sure??
TRCWRX is offline   Reply With Quote
Old 03-30-2004, 09:26 PM   #21
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
-Ben
Are you talking about Venus? I ask because some people around here have had success and others have had issues with Venus...
Old 03-30-2004, 09:50 PM   #22
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Yep
Old 03-30-2004, 10:21 PM   #23
kaos200
Member#: 2692
just get a ver 5 or newer engine, use the usdm ecu and harness, and make sure the emissions controls are hooked up (you MAY need a newer style intake manifold and those individual butterfly pieces to pass)
kaos200 is offline   Reply With Quote
Old 03-31-2004, 01:18 AM   #24
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
how will a usdm ecu work with a jdm motor? well? I don't want to disrupt the 280hp ... Would the "de-tuned" usdm ecu also be better (since it isn't tuned for 100-octane)?
-Ben
Old 03-31-2004, 04:02 AM   #25
kaos200
Member#: 2692
-Ben
well, it surely wouldnt make that 280, but once you pass the carb cert. Go get it reflashed/tuned and start making some real power
JDM vs USDM EJ20 gimpster Normally Aspirated Powertrain 28 06-02-2016 04:02 AM
gc8 with v8 usdm swap - camber issues needmoreboost Subaru Conversions 2 02-08-2007 11:51 AM
Apexi S-afc II - JDM vs USDM awd4ever Normally Aspirated with bolt-on Forced Induction Powertrain 18 03-15-2004 11:29 PM
JDM vs USDM ScoobyDoRex Off-Topic 9 08-06-2003 05:39 PM
factory STOCK JDM vs USDM upipe pics christoph1371 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-11-2002 11:25 AM
