Old 03-24-2004, 02:48 PM   #1
Mr.Hanky
Member#: 22053
2002 Black WRX Wagon
Stage 3, Element Tuned
Default Headers, Headers and more Headers?
So what can you really get out some headers?
Anyone have some real world experience with them on a WRX?
Is it only for top end power?
I know there are a few different types out there, just wanted to gather some feedback.
Let's hear it!
Steve..
Mr.Hanky is offline   Reply With Quote
Old 03-24-2004, 02:56 PM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Mid to top-end is "all" they're good for.
Get them wrapped or coated before installation. They are not very thick and lose valuable heat quickly.
wcbjr is offline   Reply With Quote
Old 03-24-2004, 03:33 PM   #3
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Have you done a search for headers in the car parts forum? Headers own.
IBtotoherbssayssaveyourmoney
Old 03-24-2004, 04:06 PM   #4
Mr.Hanky
Member#: 22053
Yeah I know but I'd rather hear from those that have them rather than those who are selling them.
Doesn't seem like a mod I will be doing unless it has accross the board benefits.
Steve..
Old 03-24-2004, 05:01 PM   #5
InfamousDX
Member#: 25413
Do they add to the turbo lag? I read on here that they added lag to bigger turbos, but I forgot what they said about the lag issue on the stocker.
Old 03-24-2004, 05:18 PM   #6
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Steve,
If you are in no hurry, downshift did some dynos with different headers.It will be published in a mag as well.
Here is the thread: http://forums.nasioc.com/forums/show...hreadid=455046
Cheers,
Sinclair
Need4Boost is offline   Reply With Quote
Old 03-24-2004, 05:39 PM   #7
blackie
Member#: 42979
03 wrx
blizzzack stage IV
i like my gruppe s v2 header, i put good numbers down, but dont know how much of it is from the header exactly., helps the top end pull the most , which is what i like the best anyways because the wrx lacks that. so for me the header is a must.
blackie is offline   Reply With Quote
Old 03-24-2004, 05:44 PM   #8
cronic
Member#: 9749
Originally posted by Unabomber
IBtotoherbssayssaveyourmoneyandposts8links
cronic is online now   Reply With Quote
Old 03-24-2004, 05:46 PM   #9
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
On my EJ257/V8 heads/PE1818 turbo car, the Borla headers added no lag and were good for about 10whp up at the very top.
Old 03-24-2004, 05:47 PM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Originally posted by Need4Boost
Steve,
Cheers,
Sinclair
http://forums.nasioc.com/forums/show...20#post5855220
http://forums.nasioc.com/forums/show...ighlight=gt30r
http://forums.nasioc.com/forums/show...s&pagenumber=1
http://forums.nasioc.com/forums/show...hreadid=518806
Let's hear it!
Steve..
Fist do you realy think in the years of this forum you are the first to ask this?
Headers are a low bang for the buck mod. The must be coated to even get close to being close to as good as iron is at retaining heat. The borlas are cheep; both in build quality and cost. If you have a built car and are running a better turbo they may give you some better gains but on a stock car its not worth it. See other threads to my reasons why.
I <3 you guys... only have 4 links today. But I have changed my stance on them... a little.
Edit: I dont know why I post links any more anyway... most of the time people dont even bother to read the threads. They just want the answer they want given to them.
"the bolt on syndrome"
Old 03-24-2004, 05:55 PM   #11
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
i can speak from experience.
I HAD P&P vf34, gruppe-s headers and all supporting mods.
max boost of 17psi @ 3600rpm.
I HAVE P&P stock headers (thanks Nino's AutoAccessories!) and same supporting mods.
max boost of 17psi @ 3300 rpm. I hit 10psi at 2900 rpm.
MikeWRX-NJ is offline   Reply With Quote
Old 03-24-2004, 06:04 PM   #12
totoherbs
Member#: 7321
.... 122 IggPoints
Were the gruppe-s coated?
Iron > steel for turbo headers.
Old 03-24-2004, 06:05 PM   #13
Dynamispeed
Vendor
Member#: 51291
2.0L WRX
GP MOTO 4-2-1 coated header
GP MOTO Turboback
GP MOTO unichip
Thats it. Stock turbo
220 WHP (header was leaking and has since been welded up. good for ~15 -20HP)
260 lb ft torque
18lbs @2900 RPM in 4th
There ARE headers that actually WORK. Check out my thread in the vendor area. I offer them coated and uncoated. I highly reccomend the coating.
Ashley
Dynamispeed is offline   Reply With Quote
Old 03-24-2004, 06:07 PM   #14
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
thermo-tec wrapped. which is was PITA b/c i had to be extra careful all the time when i was changing oil. even though they were painted.
Old 03-24-2004, 06:23 PM   #15
totoherbs
Member#: 7321
.... 122 IggPoints
Ya... that would piss me off; I get oil everywhere whne im doing mine.
GPMoto does make a nice cheep header if you are looking to go twin scroll. The subaru twin scroll headers are stupid expencive.
Old 03-24-2004, 08:58 PM   #16
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
I have a HKS header and it seems to have gained some top end, but lost low end.
neversatisfied is offline   Reply With Quote
Old 03-24-2004, 09:05 PM   #17
Nok's WRX
Member#: 25797
2002 PSM - Stock
I'll give you an update on the 17th or 18th of April. I getting tuned with the Borla headers on 93 Octane and hopefully race fuel map as well.
Nok's WRX is offline   Reply With Quote
Old 03-25-2004, 12:23 PM   #18
Dougeefresh
Member#: 11024
Weird black
Just installed Gruppe-S V2 header with Jet Hot coating. I wasn't expecting much at all but as very pleasantly surprised. I agree with blackie. Mid-top end is much more enjoyable now and I don't think I can live without it.
I took a long 3 hour highway drive after the header install and I was grining all the way , So far I have not noticed any lag (if there's any). It was well worth the $549. Btw, I have VF34 and other supporting mods.
For those of you with messy oil change problem, check this out. http://www.fumotovalve.com
It's the second best mod I got for my car! (behind the remote starter. Can't live without it in Chicago winter!) I can change oil without jacking the car up now and it literally takes minutes to change oil. Had it on since the car was new (almost 3 years) and no problem whatsoever.
Dougeefresh is offline   Reply With Quote
Old 03-25-2004, 12:25 PM   #19
Dougeefresh
Member#: 11024
Weird black
Old 03-25-2004, 02:00 PM   #20
Benjamin Tang
Member#: 4496
2009 Forester
red
guys... how do headers change the sound of the car in any way?
and what are the telltale signs a header is leaking?
Benjamin Tang is offline   Reply With Quote
Old 03-25-2004, 02:09 PM   #21
Dougeefresh
Member#: 11024
Weird black
Sound is a bit louder and deeper but not significant enough. I hardly notice the increase.
I can't tell you about the leak as I have not experienced one yet.
Old 03-25-2004, 02:18 PM   #22
WRXMikeH
Member#: 30577
2003 WRX
If it's leaking, you'll know it. It can sound like a ticking if it's minor...or a banshee if it's somewhat major. It's nasty. That, and the fact that you're not building boost like you should be.
WRXMikeH is offline   Reply With Quote
Old 03-25-2004, 02:21 PM   #23
totoherbs
Member#: 7321
.... 122 IggPoints
Un-equal lenth ones may make it deeper... equal lenth ones make it sound like a honda.
Old 03-25-2004, 02:24 PM   #24
Benjamin Tang
Member#: 4496
2009 Forester
red
is this at throttle or at idle?
i'm not sure what is what because my wastegate leaks on my stock td04 after installing a turboxs downpipe and it's all that i hear
Old 03-25-2004, 02:29 PM   #25
WRXMikeH
Member#: 30577
2003 WRX
Sorry, under throttle. You can hear major leaks at idle, but minor ones usually only show up under boost.
Cleaning out the garage! (Turbos, headers, harnesses, and more!) sperry Engine/Power/Exhaust 56 08-07-2009 12:30 PM
Turbo, injectors, fmic, header, downpipe and more midnight2.5rs-t Engine/Power/Exhaust 2 11-11-2008 08:06 PM
F/S MD/PA: TXS Exhaust, Header, vf22 and more, plus freebies!!! BluprlW05 Engine/Power/Exhaust 19 05-09-2007 08:37 AM
Wanted: up-pipe to headers gasket and more OvrClkdPmp MWSOC Private Classifieds 9 08-17-2006 01:24 PM
UTEC, Header/Uppipe, and More! XV8DRVR Private 'For Sale' Classifieds 6 11-30-2003 08:54 PM
Message Board Statistics All times are GMT -4. The time now is 03:14 AM.
