Old 03-25-2004, 06:33 PM   #1
x12oyx316x
Member#: 14532
2002 rexakacorolla
Platinum Silver Metallic
Default hmm. . what should i do?
i'm basically deciding which route i should go with. . i have a vf30 turbo w/ no supporting mods and i'm very short on money right now. . .all i need is to get engine mangmt and install my injectors and pump that i already purchased. i don't know if i can afford to do all that right now. . i'm more of a buy a couple small things here and there, stuff like that. . .should i leave the turbo in (set at 12psi) and just go with the other things i want to do. . .or put the stocker back on until i get enough money for EM . . would it be safe in the long run to run a vf30 @ 12psi?
x12oyx316x is offline   Reply With Quote
Old 03-25-2004, 06:37 PM   #2
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
You would be safer by running wastegate boost. I tuned a car wtih a Utec and VF30 with all other parts being stock. I ran out of fuel around 12psi.... That stock pump and injectors gotta go.. I was able to do this safely because I had timing control and the Utec knock control.
10-12 psi would be the safe limit of what I would run and even then I would refrain from doing any real long WOT pulls in taller gears. Around town stuff will probably be fine for a while.
Cya
C
AZScoobie is offline   Reply With Quote
Old 03-25-2004, 06:49 PM   #3
x12oyx316x
Member#: 14532
2002 rexakacorolla
i ran wastegate boost. . .it flutters between 15psi all the way to 20psi. . so i had to get a mbc to keep the boost steady. . from what i've heard, running a vf30 @ 16psi is in the "safe" range, but i didn't know if it was safe in the long run. . .when you ran out of fuel at 12psi. . did you feel it in the car or did you need your utec to tell you that because the car runs strong all the way to redline when it was 15psi with no problems, but i don't know what the engine is doing internally
Old 03-25-2004, 06:59 PM   #4
AZScoobie
Member#: 8785
netcom.com
Wastegate boost is accomplished by running a line from the compressor nipple to the wastegate nipple.. If you had over 10 psi with a straight line something is wrong with your wastegate and you need to fix it..
When I tuned the car I used Delta dash to log data, The Utec logging to a text file, An autronic WB AF analyzer and a $110,000 Dyno dynamics dyno. Oh and 9 years experience with EFI.
You state your car has no problems at 15 psi... I wonder how in the world you even know that... What tools did you use to determin that you had no problems? The fact that it did not blow up? heh..
Cya
Clark
Old 03-25-2004, 07:14 PM   #5
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
honestly, if you can, just pull the vf30 and wait. you will be too tempted to play with it if you leave it in.
MikeWRX-NJ is offline   Reply With Quote
Old 03-25-2004, 07:34 PM   #6
x12oyx316x
Member#: 14532
2002 rexakacorolla
by the way az. . there was absolutely no attitude involved in my response. . i was just simply asking if i can feel a difference in fuel if i'm running 12psi. . ."because the car runs strong all the way to redline when it was 15psi with no problems, but i don't know what the engine is doing internally" . . .maybe i should've said the car runs strong with no problems that i can hear or feel. . but i did mention i didn't know what the engine is doing internally. . so i really didn't appreciate that smart response. . but whatever. . no hard feelings
02 WRX. 105K service. What should I do and how much should I pay? st000 Bay Area Impreza Club Forum -- BAIC 6 10-12-2008 04:34 AM
Trespassers... What are they doing? What should I do? markman Off-Topic 102 04-08-2008 01:42 PM
Help...what could be wrong & what should I do? ted dibiase Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-05-2006 09:55 PM
What should I do? What would you do? WiredWRX Southern California Impreza Club Forum -- SCIC 14 08-01-2004 06:08 PM
('93-'01) hmm, what would you do? SRI Performance Impreza Forum 0 07-31-2001 03:43 PM
