Old 03-24-2004, 03:57 PM   #1
Storm
Member#: 5218
96L Most Over-
Developed Beater
Question Rod lengths on EJ25?
I need to find out if FHI kept the same rod sizes between 97-99. Reason being, I'm putting a set of STD '99 pistons into an otherwise unmolested 97 shortblock. I know that the stroke never changed, but compression ratios did, and the pistons are visibly different.
The 97's are flat top w/valve clearances....the 99's are dished like low-CR turbo pistons. I'm guessing the wristpin location is different? Will it smack the 97 heads going back on it?
I think I'll be alright, but I'd hate to end up with 5-8mm of slug sticking out of the block at TDC.
Timely replies appreciated.
Jay Storm
www.sourcemotorsports.com
Old 03-24-2004, 08:13 PM   #2
Section 8
Member#: 821
Thread
I couldn't remember which years were what length. The Phase 1 engines have long rods, 2 shorter rods (only the correct rods fit the crank journals, you probably know that).
97 through 98 will be the same. 99's appear to all to have been Phase 2 blocks with some DOHC and most SOHC heads as far as the impreza's. Other models might be different. Try a post in the Legacy forum if you know where your parts came from.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 03-24-2004, 09:36 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Thanks So Much Greg! I'll be checking this height very carefully.
Jay Storm
Old 03-29-2004, 06:39 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Bumping this back up.....
How is it possible to torque the inner rodbolts? Does it take a special tool, or must they be torqued "outside" the blockhalves? None of the literature I have mentions this step.
Thanks,
Jay Storm
Old 05-13-2004, 09:37 PM   #5
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
does anybody know the actual rod lengths?
mr. m is offline   Reply With Quote
Old 05-13-2004, 10:53 PM   #6
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
nevermind, i found them. i believe it is 132.2mm for the phase II.
Old 05-13-2004, 10:57 PM   #7
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
The rod length that I'm seeing on a spec sheet I have here is 5.162"
That would be about 13.11 cm
That's for a '98 EJ25 DOHC.
leondal is offline   Reply With Quote
Old 05-14-2004, 03:05 PM   #8
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
ive seen the rod length listed for the phase I as 131.7mm and have also read that the phase II rod is .5mm longer than the phase I. not a huge difference from what youve listed but enough to cause problems im sure.
center-to-center rod length on the Sti??? artdoesart Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-14-2004 10:17 AM
EJ25 pI / pII rod lengths? n2xlr8n Normally Aspirated Powertrain 3 12-08-2003 03:10 PM
Rod lengths? n2xlr8n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-07-2002 06:12 PM
WRX Rod Length... Conduit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-17-2001 01:08 AM
