Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 03-24-2004, 09:31 PM   #1
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Default 99RS Intake Manifold/WRX Injectors
Anyone who has used a MY99 RS intake manifold and WRX injectors on a 2000-2001 RS, what is required to do this? I have searched quite a bit and find people who say that it can be done, but noone who has actually done it and will share what was involved. I know I could get through it, and figure it all out on my own, but I'd rather be able to learn from your experience. I am working on a pretty tight timetable and would like to avoid any potential pitfalls in the process.
Thank you for your help.
Safir is offline   Reply With Quote
Old 03-25-2004, 04:52 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
well, you would need to drill and tap the hole for the MAP sensor in the 99 manifold. Unless you are using a standalone ecu. I haven't done this swap, cause I have a MY99. But that's one thing to consider.
Drac9 is offline   Reply With Quote
Old 03-25-2004, 05:00 AM   #3
kaos200
Member#: 2692
thats pretty much it. You remove the air bypass solenoid and lines, drill a hole for the map sensor, and install the injectors and rails like normal.
ps, I have a 99manifold and 550s for sale
kaos200 is offline   Reply With Quote
Old 03-25-2004, 07:00 AM   #4
Safir
Member#: 3873
. Paradise is
just throw the bypass in the "useless junk" pile? the ECU won't be bitter if it's missing will it?
I'm sure this will all be much more obvious to me once I have the parts in front of me. Pictures would help immensley, I'll have to remember to take a bunch when I do it myself.
Do you remember what size holes and what thread to tap? I'd like to make sure i have good, sharp bits in the needed sizes and the correct tap before I begin.
I've herd some people say there are tricks to getting the WRX injectors to seat properly due to the difference in length...
Thanks for your help so far.
Old 03-25-2004, 01:25 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
can anyone show me what that bypass looks like??
alex
Old 03-25-2004, 06:23 PM   #6
kaos200
Member#: 2692
yah when I had my 01' I just tossed that in the parts bin. No adverse affects besides CEL (which you'll get anyways)
If you take off your map sensor you'll see the size hole. The spot is there on the 99, its just blank.
Shouldnt be anything weird for the injectors, just spacers under the rails to make it sit the right height. Everyone does this.
If you were to get my injectors and some rails they'd pop right in
Old 03-25-2004, 06:50 PM   #7
Tats
Member#: 5692
WTF? YES! I am
better than you!
KAOS...are the injectors plug an play? IE no splicing.
If so...hit me with an e-mail with how much your looking for
john.leote@verizon.net
Tats is offline   Reply With Quote
Old 03-25-2004, 06:59 PM   #8
Safir
Member#: 3873
. Paradise is
this is the kind of half information that led me to make this post
details please
Old 03-25-2004, 09:07 PM   #9
Drac9
Member#: 9861
Do a search please. I covered this last time this thread cam about. Gave exact instructions for installing the injectors into the my99 rails.
Old 03-25-2004, 09:37 PM   #10
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
phattyduck is offline   Reply With Quote
Old 03-26-2004, 11:47 PM   #11
kaos200
Member#: 2692
no you will have to wire in the new clips, not difficult, two wires per injector, and they dont have a polarity either. So 10minutes tops.
99RS Intake Manifold and engine bay wiring Ozz10 Engine/Power/Exhaust 4 09-02-2009 12:45 PM
WRX Intake manifolds, 880cc Injectors, UTEC, MRT fateo66 Engine/Power/Exhaust 43 03-13-2009 11:08 AM
WTB: WRX intake manifold and injectors STi_Drift VIC Private Classifieds 0 11-21-2006 06:50 PM
WTB: Complete WRX Intake Manifold w/ Injectors outback2.5HO Private 'Wanted' Classifieds 1 07-05-2005 02:11 PM
help. looking for intake manifold part, injectors bolt to it IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-24-2002 11:15 AM
