Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 03-24-2004, 09:36 PM   #1
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Default sohc cams
How many different companies make cams for the sohc 2.5l engine? I know cobb and twe, anyone else? what cams would be good for a ej22t block and turbo later on down the road? i dont want something thats not streetable. thanks.
damonmlime is offline   Reply With Quote
Old 03-24-2004, 11:23 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Any cams you may buy for use with your SOHC and a turbo will not be a very good match for your car in NA form if you are serious about performance. NA and turbo cams have very different designs to them.
Something like the Cobb mild cams can be used with a turbo, but there is not much to be gained there once you go turbo. If you are unsure of your final plans, then stick to something like that and you will be happy with the extra horses you get while NA. The TWE ones would serve similar purpose. If you do a search you will see that both brands have fans and detractors.
Pretty much any other cams you find advertised will be either someone else selling Cobb or TWE cams, or the actual companies that make them. Names like Web, Ion, and xcelleration come to mind.
Old 03-24-2004, 11:40 PM   #3
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
damonmlime - if you're using the EJ22T block w/ the SOHC heads, you'll lower your compression; leading to less N/A hp compared to your stock EJ25 block.
Increasing lift will allow for more fuel/air to enter the combustion chamber when the intake valves are open, hence the gains in N/A form will be had when turbo'd as well.
GTBGUY is offline   Reply With Quote
Old 03-25-2004, 05:13 PM   #4
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Default sohc cams
thanks for the info, i don't think i'll spend the money on cams just yet, i was just looking for a relatively cheap power boost. i have intake, high flow cat, borla headers, cheap underdrive pulley and catback. is there anything else that could give me a boost while n/a? thanks again. Damon
Old 03-29-2004, 07:57 PM   #5
Snagtastic
Member#: 43809
You could always sell the headers and step to the equal length ones.
As for cams, Paeco also makes them.
Of the main companies that offer subaru parts: Cobb, TWE, Xcceleration, Paeco...I would be tempted to go Cobb if possible but that is just a personal preference.
I know TWE puts a good product on the street, as for the others I have no experience or testamonials on record.
Snagtastic is offline   Reply With Quote
SOHC cam sprockets 970subaru Subaru Conversions 2 05-22-2006 07:30 PM
WTB: rs sohc cams gc835 Private 'Wanted' Classifieds 3 03-15-2006 09:38 PM
WTB: Stock 2.5RS SOHC Cams Kcz Private 'Wanted' Classifieds 0 11-19-2004 03:41 AM
TWE Stage II Street/Rally SOHC cams Akarui Normally Aspirated Powertrain 8 10-04-2004 10:14 AM
SOHC Cams, what's involved? Fish Normally Aspirated Powertrain 15 09-05-2001 09:31 AM
