Old 03-24-2004, 09:50 PM   #1
crk4
Member#: 43617
1976 Ford Bronco
R.I.P. Mark Vos, 96 ob
Default CEL code P0106 Pressure sensor circuit range/performance problem (low input)
I just ran the code for my damn CEL and its
Whatever the hell that means. Any ideas? Is it with the intake manifold?
It says performance problem and I think I have a loose bolt on the MAF, but I'm not sure what it is...it could be that because when I did the snorcusectomy, I took it apart too far and messed...
Any ideas?
crk4 is offline   Reply With Quote
Old 03-25-2004, 09:43 AM   #2
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
where did you get this checked? call a dealer, they can tell you over the phone....
2pt5RS is offline   Reply With Quote
Old 03-25-2004, 01:53 PM   #3
crk4
Member#: 43617
1976 Ford Bronco
OBD2 plug in to my laptop. I removed the check engine light and it actually got fixed.
MOD: Please merge into CEL thread if possible.
Old 03-25-2004, 05:23 PM   #4
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
glad I could help
Old 07-17-2005, 02:40 PM   #5
optimusprimerib
Member#: 23665
1997 Legacy GT
Red
Vacuum leak, yo.
optimusprimerib is offline   Reply With Quote
P2138 Accelerator Position Sensor Circuit Range/Performance HELP! shop man. owners modaddict Factory 2.5L Turbo Powertrain 9 10-04-2010 04:14 PM
check engine light code P0137 o2 sensor circuit low voltage bank 1 sensor 2 duque Engine Management & Tuning 1 05-09-2010 01:43 AM
CEL 1153 O 2 Sensor Circuit Range/Performance (High) (Bank1 Sensor1) Dmoney8053 Newbies & FAQs 4 08-30-2009 01:11 PM
'99 RS 2.5L - Erratic Idle, CEL code P0106 ?? w chapman Service & Maintenance 0 06-04-2006 08:35 PM
p0336, Crankshaft Position sensor Circuit range/ Performance problem? Who has had it? eightballrj Factory 2.0L Turbo Powertrain 3 02-28-2004 09:04 PM
Message Board Statistics All times are GMT -4. The time now is 04:16 PM.
