Old 03-24-2004, 10:17 PM   #1
brotherx
Member#: 36114
2003 WRX Wagon
Default Daytime Running Lights - Quickest disconnect?
Just looking for the easiest/safest way to disconnect the DRLs.
Sounds like there is a plug somewhere, but I'm not sure where.
-Thanks
brotherx is offline   Reply With Quote
Old 03-24-2004, 11:16 PM   #2
GLwagon
Member#: 16696
'02 MBP WRX Sedan
Ooh, you touch my TraLaLa
Originally posted by brotherx
...the easiest way to disconnect the DRLs...
Engine bay, passengers side, down by the frame between engine & strut tower, shiny silver box marked "HOT" (one plug, with 2 wires). Unplug, zip-tie so wires not dangling, done.
GLwagon is offline   Reply With Quote
Old 03-24-2004, 11:30 PM   #3
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
that may the quickest, but if you are running HIDs not the best way.
drop the glove box, find the green plug marked DRL right in front of you, unplug. re-install glove box.
time 15 minutes, tools screw driver.
MikeWRX-NJ is offline   Reply With Quote
Old 03-24-2004, 11:33 PM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
Yeah. . .do the one next to the glovebox. That's the actual DRL module. The one in the engine bay is just a resistor pack.
Calvin
cnk is offline   Reply With Quote
Old 03-25-2004, 12:02 AM   #5
brunetmj
Member#: 8023
2004 2.5 RS
brunetmj is offline   Reply With Quote
Old 03-25-2004, 01:05 PM   #6
Orson
Member#: 25254
2003 WRX wagon
I did the one under the glove box. I didn't have to disassemble anything - I just reached in and disconnected.
Orson is offline   Reply With Quote
Old 03-25-2004, 05:27 PM   #7
PsiRRizzed247
Member#: 17503
2002 05450x
ride red!
hey, would that be the reason my hid's on 02 sti projectors would come on right when I release the p-brake? hehe I only disconnected the tic tac box.....
PsiRRizzed247 is offline   Reply With Quote
Old 03-25-2004, 08:56 PM   #8
cnk
Member#: 10757
Yes. . that's why your HID's come on. Pull the plug by the glovebox and it won't happen again.
Calvin
Old 03-25-2004, 08:58 PM   #9
WRXsPWN
Member#: 35989
2011 Sti sedan
yeah look at that picture then open your pasenger side door reach your hand under the dash at the very right side feel around till you feel some plugs it is the front most one, pull it out and wala, i have never seen it as i didnt feel like squating down i just reached under foudn it pulled it and it was even the right one the first try. very easy.
WRXsPWN is offline   Reply With Quote
Old 03-25-2004, 09:03 PM   #10
brunetmj
Member#: 8023
2004 2.5 RS
Yes it can be done that way if you know exactly where it is and have nimble hands and body. For an old guy like me taking off the glove box is a better option.
daytime running light uninstall with jdm lights? bren wrx Electrical & Lighting 1 09-20-2005 09:08 AM
Question: brake light on, clock light out, daytime running light out PhoKingWRX Electrical & Lighting 2 05-22-2005 07:29 AM
('93-'01) How to remove daytime running lights on 2002 Imprezas Dr. Spud Funk Impreza Forum 9 05-08-2001 05:43 PM
daytime running light 2kGT Bay Area Impreza Club Forum -- BAIC 1 06-05-2000 05:13 PM
Message Board Statistics All times are GMT -4. The time now is 03:06 AM.
