Old 03-24-2004, 11:44 PM   #1
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
Default CompuStar & Blitz
Does anyone know how to wire a Blitz Fatt DC III Turbo Timer up with a CompuStar Spectra Remote Start / Alarm so that they work together. I'm having a bit of trouble getting them to not confuse each other.
Thanks
blkwrx02 is offline   Reply With Quote
Old 03-25-2004, 03:42 PM   #2
Benjamin Tang
Member#: 4496
2009 Forester
red
sorry for not being more helpful but i have the same setup and it does work together... but the installer who did it for me dosen't want to give up how to do it because it took him a long time to figure it out
Benjamin Tang is offline   Reply With Quote
Old 03-25-2004, 03:53 PM   #3
WolfDrive
Member#: 49506
2004 Impreza WRX STi
Java Black
I think the main problem is getting the car to lock after you get out with the turbo timer still going. I dont know about your compustar but mine has a turbo timer built in that gets rid of all the problems. If you give more detail about your timer and the alarm you have I can probably help. I have installed 3 compustar alarms on my cars so I know the company pretty well, and because I'm not affiliated with anyone, I'll give what I know freely.
WolfDrive is offline   Reply With Quote
Old 03-25-2004, 04:06 PM   #4
netZ
Member#: 5743
2007 Kia Optima
gold brick
if you don't plan on using the compustar's built in turbo timer you just need to isolate the ignition sensing wire off the alarm system.
a member mentioned moving the alarm's ignition sensing wire to the accessory wire, but this will prevent your starter kill relay from interupting the starter wire when someone tries to start your vehicle while the alarm is armed.
you can use a relay to do this here.
netZ
netZ is offline   Reply With Quote
Old 03-25-2004, 07:32 PM   #5
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
I think I had that setup but without the diode. That could be what I'm missing.
Thanks
Old 03-26-2004, 06:18 AM   #6
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
Hey, my wife works for tech support for Compustar, I'll have her take a look at this thread in the morning.
scrappydoo is offline   Reply With Quote
Old 04-24-2004, 12:14 AM   #7
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
scrappydoo, Did your wife ever find out anything?
Old 04-24-2004, 11:38 PM   #8
it8ezbngrn
Member#: 35590
Ok- The relay need to isolate the compustar from the ignition .
The compustar Ignition wire needs connected to the #87A pole of the relay.
The Turbo timer output needs to be connected to the #87 pole and the 86 pole. Connect the E brake wire to the 85 pole. Connect the#30 Pole to the cars Ignition wire.
What this will do is when the TT is on ,Ignition wire to the Compustar will be disconnected. Allowing it to arm. OK Look at my post about "relays for dummies " on scooby mods.com It wil explain a lil more how the relay works.
PS I wire alarms and TTs at a shop in Tacoma WA. So I'm no shade tree.
it8ezbngrn is offline   Reply With Quote
Old 07-08-2004, 08:52 PM   #9
sqhootie
Member#: 64807
Smile
hey it8- thanks a bunch...this relay did work. Yee haa.
You are my hero
TH
PS Compustar tech support didnt help
sqhootie is offline   Reply With Quote
Old 10-26-2004, 10:09 PM   #10
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yo
anyone do this? the link isnt working for me?
i need to find out ?!
thanks
alex
Old 10-26-2004, 10:13 PM   #11
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
Yeah the directions from NetZ and it8 worked great. Follow them and you should be ok. The link to NetZ's diagram doesn't work anymore so just use it8's directions.
F.S.: Blitz BOV & Blitz EBC Jezek NESIC Private Classifieds 11 05-15-2007 06:46 PM
Blitz Nur-Spec R & Blitz Nur-Spec RX Catbacks- IN STOCK! 201Motorsports Engine/Power/Exhaust 14 02-27-2007 12:44 PM
fs: aps tmic & blitz bov & pioneer dvd-a player m@stro TXIC Private Classifieds 4 10-23-2006 11:00 AM
FS: Blitz D-SBC Type R & Blitz DTTX mnkypsycho Private 'For Sale' Classifieds 2 06-10-2004 12:49 PM
Byron's bringing a couple of Chalak Flywheels & Blitz Intake Kits up here! B-SpecUSA Bay Area Impreza Club Forum -- BAIC 7 07-21-2001 04:23 AM
