Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 03-24-2004, 11:02 PM   #1
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
Default Problem with vacuum
Yesterday I had a vacuum leak from the hose that goes to my boost gauge. This is like the fifth time this has happend where the hose cracks where it connects to the rest of the hoses. I cut off the bad part and reattached it. When it leaks it usually reads about 10inHg and when solid 20inHg. Well after fixing the hose my boost gauge is reading like 18 inHg, with my foot off the gas, for the first 10 minutes or so then drops down to 20inHg. The only thing i can think of is that the pistons are heating up and making a tighter seal in the cylinder which would cause more vaccum but as far as i can remember after startup the car would always stay at 20inHg. Not sure if this is too little of information but is there any other reason this would happen or is this just normal operation and i just didnt notice the gauge reading greater vacuum after driving for awhile?
-Marc
boysetsfire is offline   Reply With Quote
Old 03-24-2004, 11:21 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
first I would suggest getting the thick walled silicon hoses...I think they are made by yakimohto or something like that
Old 03-24-2004, 11:41 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
My car usually reads 15-20 when cold, then once it warms up goes to about 20-25. I think its more related to RPM though, because it idles a bit higher when cold.
lotusTT is offline   Reply With Quote
Old 03-25-2004, 03:39 AM   #4
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
Pretty sure that's normal operation. My Camry and WRX are the same way...
-Charlie
phattyduck is offline   Reply With Quote
Problem with vacuum lines? NightHawk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-08-2008 03:52 PM
Help asap with vacuum problem berts2000rs Newbies & FAQs 1 07-09-2008 04:26 PM
BOOST PROBLEM & VACUUM HOSE Question Big Kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-04-2006 12:09 PM
Dawes MBC with vacuum hose Saladin Private 'Wanted' Classifieds 1 01-20-2004 03:32 AM
please help with vacuum gauge install Jonathan_Yi Interior & Exterior Modification 4 06-24-2001 06:36 PM
