Old 03-24-2004, 11:51 PM   #1
neurotic
Member#: 8161
Default Lowbeam problems with morettes
I have had morettes installed on my 02 wrx for over a year now with no problems until tonight. I turned on my headlights and they flickered a second and were dead. I checked all my fuses, wiring connections etc but everything was fine.
It's too dark to see much right now, but I managed to try hooking up one of my old lowbeam bulbs from the stock headlights and it lit up fine, but started making a hissing noise and turned white after a few seconds of being on.
My highbeams work fine, city lights, everything else.
Could something be causing some type of power surge to the low beams?
Thanks.
neurotic is offline   Reply With Quote
Old 03-25-2004, 06:28 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Do you have Volt meter?
can you measure the voltage to the low beam connector to verify in fact the problem is a to much voltage?
Did you have the car running when you plugged in spare bulb?
Jay
Old 03-25-2004, 11:04 PM   #3
neurotic
Member#: 8161
The car was off when I plugged in the spare bulb.
and I don't own a voltage meter but I am going to borrow one from a friend tomorrow since I have the day off. Thanks for the reply.
Weird problem with morettes and HID help Porkchop-WRX Electrical & Lighting 7 03-13-2007 04:57 PM
problem w/ morette installtion chobits Interior & Exterior Modification 9 02-08-2003 12:03 AM
Problems with Morettes ElDuderino Electrical & Lighting 12 02-04-2003 06:40 AM
Got a problem with my morettes rochyrex Interior & Exterior Modification 2 08-23-2002 10:23 PM
White 2002 WRX with Morettes WRX02 Interior & Exterior Modification 2 08-12-2001 05:08 PM
