Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Vancouver Impreza Club
Old 03-25-2004, 02:59 AM   #1
C0met
Member#: 54519
2004 Mercedes Benz
C230 Kompressor
Default Air Sound
When I am going about 100KM/H, I can hear this air sound coming through the driver side window. When I open and close it the sound is gone. This only happens sometimes. Anyone else having this problem?
C0met is offline   Reply With Quote
Old 03-25-2004, 04:01 AM   #2
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Yes, it's probably just the seal between the window and rubber trim that isn't perfect when you roll the window up, but it goes away when you properly shut the door with the window up.
Ken is offline   Reply With Quote
Old 03-25-2004, 04:27 AM   #3
fukamoto
Member#: 13339
2014 SWP WRX Wagon
I hear that too
Wonder if this was before my door got fixed or after?
fukamoto is offline   Reply With Quote
Old 03-25-2004, 09:49 AM   #4
Benjamin Tang
Member#: 4496
2009 Forester
red
Default Re: Air Sound
welcome to the world of framless windows.... and u should be doing the speed limit!
Benjamin Tang is offline   Reply With Quote
Old 03-25-2004, 10:25 AM   #5
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Even worse, look at the rubber edge, follow it along the top of the driver/passenger side windows. See that seam near the top? If you go through a touchless car wash (yeah I know) water just pours in through that seam..
I have a water soaked bubble in the door panel right below that seam and I think subaru should change the panel cause it's not supposed to be leaking..
420WRX is offline   Reply With Quote
Old 03-25-2004, 10:53 AM   #6
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
There are a set of adjustments you can perform to fix the alignment of the window. Check the service manual for information -- it involves pulling off the doors, and it's a royal pain in the ass.
Necromancer is offline   Reply With Quote
Old 03-25-2004, 11:19 AM   #7
aawen
Member#: 27167
2015 FXT
it happens when I go faster than 190
but mine is in passenger side
aawen is offline   Reply With Quote
Whistle/Moving Air Sound at 2k Need BB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-27-2005 08:19 PM
Snorkel removed, humming sound coming from air box...? fastenova Legacy Forum 8 06-28-2003 12:02 PM
