Old 03-25-2004, 08:47 AM   #1
sneeky
Member#: 44639
STi
the 35 awaits you...
Default Wiring through the firewall
i'm assuming as far as firewall grommets and wiring all rex's are the same...? however, which one are people using? the one under the driver side pedals? cause i did that but now the grommet is out and i can hear everything in my engine bay.... and it sounds ghetto as hell. anyone have any suggestions?
chris
sneeky is offline   Reply With Quote
Old 03-25-2004, 09:32 AM   #2
Aegon
Member#: 42435
Cut an X in the grommet and run the wires through the hole.
Aegon is offline   Reply With Quote
Old 03-25-2004, 10:32 AM   #3
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
ding ding ding!
of course, you'll be sad if you didn't do that to start with and have to re-run a lot of stuff. Something I've seen after my last big audio-install... there were many huge-ass wires coming through, too much for the gromet to handle, so the installer used this sort of gummy gray putty stuff to fill in the gap. around the wires. I have no idea what it's called or where you'd get it, of course.
bleuquila is offline   Reply With Quote
Old 03-25-2004, 10:47 AM   #4
Aegon
Member#: 42435
Butyl Rubber will help fill the gap. Try a bike-tire patch kit!
I haven't done this, but it will probably work A-OK.
Old 03-25-2004, 11:06 AM   #5
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
Home Depot sells a block of this stuff in the HVAC section.
It looks kinda like a block of C4 (if you watch movies). It's a putty called "Pug Duct Seal".
It's moldable and will plug the hole nicely. WHen it dries it is practically permanant. May or may not be a good thing.
mbeach is offline   Reply With Quote
Old 03-25-2004, 05:30 PM   #6
PsiRRizzed247
Member#: 17503
2002 05450x
ride red!
assuming you still have the stock grommet? if so this is your best bet.
and yes this is where I ran wire, etc.
my .2
PsiRRizzed247 is offline   Reply With Quote
Old 03-26-2004, 09:21 AM   #7
sneeky
Member#: 44639
STi
i pushed the stock one through by accident and looked under the car and it wasn't there i'm assuming it got stuck in the undercarriage somwhere, so i just bought a new one... but luckily i only ran one wire so far... so this is what i'll be doing at work today
chris
Old 03-26-2004, 09:27 AM   #8
mbeach
Member#: 39807
it probably fell on the little "shelf" that is under the brake booster. You can't see it from above or below, you just have to feel for it from under the car. -Unless you've driven it since then.
Old 03-27-2004, 10:01 PM   #9
WRX-ECE
Member#: 12091
Old 240Z Broken
Rally car, 350z, 98 RS
Take the intercooler off. It makes life a hell of a lot easier when running wires around the engine bay.
And I use the dirver side gromet too. Cut a slit in it and fed the wires threw.
Jeremy
WRX-ECE is offline   Reply With Quote
Best place to thread the battery power lead through the firewall? Patu Car Audio, Video & Security 10 04-26-2007 09:36 AM
Running wires through the firewall? SubieWahn Electrical & Lighting 2 11-02-2005 01:21 PM
Whats the best place to route wire through the firewall Psyk Car Audio, Video & Security 8 09-01-2005 11:58 AM
WRX harness through the firewall on an RS swap Zephyr Subaru Conversions 3 12-06-2003 09:26 PM
Where should I run wires etc. through the firewall? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-22-2001 12:22 AM
