Old 03-25-2004, 02:03 PM   #1
wagonman
Member#: 971
Default annoying clicking when cold?
Does any body have an idea what might be causing a loud click/tick noise when the car is cold? it will continue to make this noise until about 15 mins. after the car has warmed up.
exhaust leak maybe, i did just put a spt exhaust on it...sounds kind of like it is coming from where the header meets the cat. any helps is greatly appreciated and thank you in advance.
Jeff
wagonman is offline   Reply With Quote
Old 03-25-2004, 10:21 PM   #2
wagonman
Member#: 971
anybody??
Old 03-25-2004, 10:29 PM   #3
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Is it kind of the internal click? Almost like a slight rythemic knock?
It may be the valve train noise, it's been common among the EJ engines. I even have it in my EJ25. And yes it goes away when it's cold. Subaru tells us it is normal, however if the noise doesn't go away after warm up, there may be a problem.
-paK +1
Pakin is offline   Reply With Quote
Old 03-26-2004, 12:12 AM   #4
obyone
Member#: 16523
Jeff
You may have the same problem I had.
Read through my old thread and see if it is or isn't.
http://forums.nasioc.com/forums/show...hreadid=297045
obyone is offline   Reply With Quote
Old 03-26-2004, 12:26 AM   #5
wagonman
Member#: 971
it doesn't sound like the normal ticking, it does have a rythem to it...as the revs increase , the noise also speeds up with it, anyone think it could be an exhaust leak? thanks again for the help.
Jeff
Old 03-26-2004, 12:29 AM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
The only think I can think of now is a near rattle of the heat shield. It doesn't have to rattle, but just "tap", near the threashold of the shield loosening but not loose.
-paK +3
Old 03-26-2004, 12:34 AM   #7
wagonman
Member#: 971
i just had the timing belt replaced...so with my luck it is a belt tensioner going bad...i guess 170K miles isn't too bad but the point at which it happens is skewed a bit. thoughts? inspirational speeches? i am open for anything at this point.
Jeff
Old 03-26-2004, 12:40 AM   #8
wagonman
Member#: 971
i will check the heat shields tomorrow when i replace some gaskets that need replacing, thanks for the tip!
Jeff
Old 03-26-2004, 01:05 PM   #9
Nicklbrso
Member#: 44887
00 GC6
It could be a noisy lifter
Nicklbrso is offline   Reply With Quote
Old 03-26-2004, 03:21 PM   #10
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
Don't worry about cold clicking. all the EJ25 does that. Well it can come from the timing belt tensionner. this source worth repairing, because if the tensionnor break, say adios to your valvetrain. otherwise it's piston slapping caused by too much clearance when cold. as long as it's only when the engine is cold, don't worry about it. if it still does after hour of driving it's a concern. I've been told at the dealer i work in the summer that even if the engine still tick at hot, it can do a lot of mileage. we've seen a legacy GT with 400 000 km on the first engine...
NicEJ25 is offline   Reply With Quote
Old 03-26-2004, 08:43 PM   #11
2002 GT LTD
Member#: 19144
2002 Legacy GT Sedan
Titanium
I had it for a long time.
They replaced the Timing Belt Tensioner and the noise did not go away.
It sounds like piston slap or bearing knock when you are driving.
The dealer, put in a new shortblock. problem solved.
The fix now is to replace the pistons with better fitting ones as the sleeve is short on the existing piston and causes them to wiggle a bit when cold.
Good luck with it.
2002 GT LTD is offline   Reply With Quote
Old 03-26-2004, 10:22 PM   #12
obyone
Member#: 16523
Good luck with it.
My belt tenioner was the cause for mine...and I had the exact same issue Wagons.whatever has....I'm just saying...
Old 03-27-2004, 12:58 AM   #13
Davidhtam
Member#: 30107
90 Acura Integra
Melbourn Blue Metallic
Could be power steering aswell, but that would only happen when you're turning.
Davidhtam is offline   Reply With Quote
Old 03-27-2004, 05:10 AM   #14
joefocker20
Member#: 13745
2015 STI
All Subaru's valves tick when they're cold, my 02 RS and also my 00 RS both do it. This is even at idle, and not like David said, the sound that David said is more of a grinding, dying sound..
joefocker20 is offline   Reply With Quote
Old 03-27-2004, 09:12 AM   #15
obyone
Member#: 16523
........um. Mine doesn't tick, when cold, anymore. The sound of the engine note, from the compartment, stays reletivly (Sp?) the same as it's warming up and after it's warmed up.
Old 03-27-2004, 01:10 PM   #16
wagonman
Member#: 971
i got my noise figured out...simply an exhaust leak that a $7 gasket cured, but thanks for all the help...thankfully it wasn't a belt tensioner.
Jeff
Old 04-26-2004, 09:41 PM   #17
Jejunum
Member#: 15773
2011 Impreza WRX
Jeff
where was ur exhaust leak?
Jejunum is offline   Reply With Quote
Cold Start click when accelerating Subee05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-14-2010 04:21 PM
annoying clicking ceecel Brakes, Steering & Suspension 2 03-20-2010 07:47 PM
My car idles lumpy when cold but is fine when warm? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-03-2004 05:37 PM
clutch shudder when cold or damp or cold and damp on MY02 WRX caut10n Newbies & FAQs 12 10-07-2003 09:31 PM
Squeeky Rear Suspension when Cold, goes away when warm. nhalterman Brakes, Steering & Suspension 2 12-12-2001 04:31 PM
